NEED HELP QUICK!!! Stripped Torque Converter Bolts
Old Oct 21, 2006 | 03:51 PM
benvortec's Avatar
Default NEED HELP QUICK!!! Stripped Torque Converter Bolts
I'm in the m,iddle of my tranny pull and can't get those damn torque converter bolts out. I may haave stripped one,l the just won't budge. Any suggestions, it's those damn hex bolts any suggestiopons?
Old Oct 21, 2006 | 03:59 PM
blksilverado's Avatar
take a torx bit that will fit barely, then tap it in with a hammer. go easy on it, should break loose. other than that, i don't know what to tell ya
jakebdb56's Avatar
soak it with some wd-40 for an hour or so and try again.
Old Oct 23, 2006 | 11:25 AM
vanillagorilla's Avatar
I had the 8mm or whatever allen head bolts on mine and I stripped one real bad. I had to get in there with a dremel and a cutoff wheel and grind the head off. It took about an hour and it wasn't fun.
Old Oct 23, 2006 | 11:30 AM
dirt track racer 81's Avatar
hahaha have fun buddy..i had to use a torch and cut off two of mine.damn dealership when they repace my two transmission stripped them out and only replaced one...i cut into the flywheel just a lill bit..but had no problems yet..
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
