Need help plumbing fuel cell 06 4.8
Old Mar 22, 2012 | 05:00 PM
camdiddy's Avatar
Default Need help plumbing fuel cell 06 4.8
Bought a project truck, 06 silverado with 4.8, came with fuel cell and factory pump. I have read about these truck's "returnless" fuel system. I plan on running fuel injection hose. But other than the main feed, and what I believe is the evap line, what is the other line? considering theres no return, right?
Old Mar 22, 2012 | 05:50 PM
CAGRacing's Avatar
Charcoal canister?
Old Mar 22, 2012 | 06:47 PM
Atomic's Avatar
I have a gauge for that
the big one is part of the evap system and goes to the canister that used to be on the side of the tank. You can just cap it off as long as the tank is vented in some way.
Old Mar 22, 2012 | 09:10 PM
camdiddy's Avatar
yeah i was going to run a threaded vent in the port you see on the back of the cell. So the largest diameter tube? cap that? and the smaller one, below that in the pic, is the main fuel supply?
Old Mar 22, 2012 | 09:36 PM
Atomic's Avatar
Correct, the small one in front is the feed line.
Old Mar 23, 2012 | 11:00 AM
camdiddy's Avatar
thank you. I also have the ls1 intake swap almost complete on my truck. not sure if theres a return port on the rail or not. I know theres a fuel pressure regulator. Will i just cap the return port if it has one?
lsxperformance
Feb 2, 2020 01:07 AM
greedygenius
Sep 3, 2015 06:51 AM
RS/SS 4.8
Aug 2, 2015 11:03 PM
MS3Z
Jul 30, 2015 06:17 PM
