Need help with old slow z71
Old Nov 15, 2004 | 06:20 PM
P.O.R.N.'s Avatar
Default Need help with old slow z71
Hay guy i need a hand on finding out what i can do to bring some life back to my dads 94 silverado. I know its not the ls1 but looking for some advice. We have changed the cap, rotor, plugs, wires, fuel filter, no cats, new single 2.5inch exhaust, the fuel pump has good presure and the ingecters have good spray. it has 114000 miles on it and has been driven very slow. Could the cam be worn out?
Old Nov 15, 2004 | 07:43 PM
Do a motor swap.
Old Nov 15, 2004 | 09:32 PM
chevymec's Avatar
305 or 350?
Old Nov 16, 2004 | 09:07 PM
P.O.R.N.'s Avatar
Its a 350. It once had a lot more power but just resently started to die out. Looks great and runs smooth just powerless.
Old Nov 17, 2004 | 04:06 AM
If you got the 350, I say rebuild it and make it a 383 stroker. You will get plenty of power even with a mild 383.
Old Nov 18, 2004 | 08:37 PM
take it out and rebuild it. increase the compression and use hyperutectic pistons with ARP bolts through out. get a set of vortec heads with comp cams triple springs and go full roller.279/280dur.479 lift for your cam should be allright. do not use stock springs they can only handle about 465 lift. your 94 may already be roller. if you go with a large cam then the stock computer will go crazy. get rid of you TBI.go TPI off of a camaro or vett unless you are running a 4L60E. if you are running a 4L60E tranny then you will have to call painless to get a wiring harness and computer to make the TPI run your 4L60E. there is alot of wiring involved but after you are done you will have a screaming motor and your check engine light will still work were as if you go with a system from holley or someone the engine wont tell you when something is wrong. painless has a book that will pretty mutch walk you through the swap. For the intake and injection system i have one that is complete off of a vett. all it needs is a motor under it. pm me if you are interested.
Avalanche2002
Nov 30, 2015 07:31 AM
cheyenne383
Nov 13, 2015 09:24 AM
drummer0415
11
Oct 24, 2015 08:16 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
