Need Help. Load Roaring at Front of Truck.
Old Feb 19, 2004 | 10:59 AM
CrimeSScene's Avatar
12 Second Club
Question Need Help. Load Roaring at Front of Truck.
Ok, for a daily driver, I have a '98 GMC Z71 with 102000 on the clock......
As said above, I have a roaring noise that is definetly coming from the front end. It almost sounds like my tires, but I can feel it in my pedals and my steering wheel. The sound changes slightly when I turn my wheels slightly. It sounded like it was coming more from the passenger side, so I replaced the passenger hub day before yesterday. I test drove it and the noise was still there.I checked the fluid in my transfer case last night and I couldn't touch any at all with my finger. I added some Dexron III and filled it up, but the noise is still there, loud as ever. Could my transfer case be perma-screwed or could it be something else. Neither of my axles have broken joint covers on them, so I can't see the sound coming from there. 4 wheel drive still works normally for now. I don't want to have to replace my transfer case, but......
Any advice would be greatly appreciated.
Old Feb 19, 2004 | 12:17 PM
burbman's Avatar
Couple of things to check:
1) Is the sound your clutch fan in permanent lockup mode? They can be really loud.
2) If the sound changes when you turn the wheel, have you checked your power steering pump?
If the noise is only present when the truck is moving, I would also look to see if there could be a problem with sticking brake calipers or rubbing suspension parts.
Old Feb 19, 2004 | 12:46 PM
12 Second Club
1) fan clutch is still working
2)It does only make the sound when It's rolling. As far as turning, I actually meant that If I turn the wheel slightly one way or another when moving (as in changing lanes) the sound will go away slightly or increase slightly at times (definetly a noticable change though). The sound does change the faster or slower I go though.
I checked for anything rubbing already, and I cant see anything. I will check my brake calipers though.
Thanks
Old Feb 19, 2004 | 04:18 PM
silent1's Avatar
Sounds like your wheel bearings but, I've also experienced this from damaged C.V. shafts.
Old Feb 20, 2004 | 11:55 AM
12 Second Club
I think it is the wheel bearing. Took it to a transmission shop and the guy drove it and said it was not the transfer case but the passenger wheel bearing.....which is what I thought it was too and the one that I just replaced. Guess I screwed up somewhere. Hope Oreillys honors there lifetime part guarnatee cause I'll be taking it back tonight for a new one.
Old Feb 21, 2004 | 08:20 AM
LS1NOVA's Avatar
Make sure it isnt the left front. Sometimes when doing the old weave from side to side
manuever to determine which side it is, it will trick you.
Zizzle
Oct 19, 2017 08:44 PM
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
Nimoryan
Jul 5, 2015 03:50 PM
