NEED HELP LADDER BARS OR TORSONS BAR
Old Apr 24, 2002 | 07:04 PM
00 silver toy's Avatar
Default NEED HELP LADDER BARS OR TORSONS BAR
DOSE ANY ONE KNOW WHERE TO GET LADDER BARS FOR A STOCK HIGH SILVERAOD
BEEN LOOKING AROND BUT EVER THING IS FOR AT LEST A 3 IN LIFT
ANY HELP WOULD BE GREAT
CJ
Old Apr 24, 2002 | 08:25 PM
Phatchevy's Avatar
Default Re: NEED HELP LADDER BARS OR TORSONS BAR
i could be wrong about this but i think those are two different things. torsion bars are for 4x4's meaning it jacks up the front end or lowers it. the higher the setting will lift the front end but also give a rougher ride. the ladder bars are another name for traction bars. hopefully someone else can confirm this. what are you going for?
Old Apr 24, 2002 | 09:24 PM
CHAGO's Avatar
yes, ladder bars are for traction...mostly on race cars.... similar to traction bars, but also different!!
here's a definition:
Torsion Bars
Torsion bar suspension uses the flexibility of a steel bar or tube, twisting lengthwise to provide spring action. Instead of the flexing action of a leaf spring, or the compressing-and-extending action of a coil spring, the torsion bar twists to exert resistance against up-and-down movement. Two rods of spring steel are used in this type of suspension. One end of the bar is fixed solidly to a part of the frame behind the wheel; the other is attached to the lower control arm. As the arm rises and falls with wheel movement, the bar twists and absorbs more of the road shocks before they can reach the body of the car. The bar untwists when the pressure is released, just like a spring rebounding after being compressed. Adjusting the torsion bars controls the height of the front end of the vehicle. The adjusting bolts are located at the torsion bar anchors in the front crossmember. The inner ends of the lower control arms are bolted to the crossmember and pivot through a bushing.
Old Apr 24, 2002 | 09:25 PM
sorry i ment to write trac bar not torson looking to dress up the truck and get some better hook ups
Old Apr 25, 2002 | 02:59 AM
Phatchevy's Avatar
caltrac is supposed to have a good set of traction bars for our truck. they cost around $320. i've only heard of a couple people that have them, maybe they could give you more information about them? hope that helps...
Old Apr 26, 2002 | 10:01 PM
DOSE ANY ONE KNOW IF CALTRAC HAS A WEB SITE OR WHERE TO GET THE AT
THANKS
Old Apr 26, 2002 | 11:59 PM
Brandon Boomhauer's Avatar
http://www.calvertracing.com/
I dont see a link on their site phatchevy
Old Apr 27, 2002 | 06:16 PM
Phatchevy's Avatar
well i didn't see the traction bars on their web site either, but i went ahead and email them asking if they had a set for the 99-02 silverados, also asked if i had to do anything special because i have the hothckis 2/4 drop and they said:
Yes we have a set of bars to fit your application. However we would
need to modify your front spring hanger in order for our system to bolt
in properly. You can also order new hangers that are already modified
for $105 for the pair. Our bars would eliminate wheel hop and spring
wrap up. The price of the bars is $319 plus shipping. If you have any
further questions please call (661)948-1490
Yes, we have to modify your front hanger do to the drop. We have to
remove 2" of material out of the hanger then reinforce it on the top side
of it. If it had the stock hanger there would be no problems. Thanks
Travis@calvert Racing
<small>[ April 27, 2002, 06:18 PM: Message edited by: Phatchevy ]</small>
Old Apr 27, 2002 | 06:46 PM
Im guessing there wouldnt be a problem if one went with a 2/4 with 4in leafs would there?
Old Apr 28, 2002 | 02:34 AM
Phatchevy's Avatar
you just have to modify your front leaf spring hanger because of the 4" drop. i will probably do the traction bars at the end of summer. i used to have really bad wheel hop but now i don't. going to wait and see what happens when i get the flex-a-lite fan here in a week or two.
carid
Oct 28, 2015 08:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
