need help with fuel bleeding off on 97 k2500
Old Jan 31, 2004 | 12:56 PM
sounds like the regulater to me too because it misfires a little on start up. reg. was only about $50 when I checked on it yesterday.Also what are you calling the upper plenum on this is it the black plastic part where the throttle body bolts down just above the aluminum intake or above the throttle body where the air comes in, and how long does it usally take to do a regulator?
thanks again for your help Ive had a diesel for a long time and have never had this type of system on any of my trucks.
Old Jan 31, 2004 | 03:20 PM
LS1NOVA's Avatar
Yes, the upper plenum is the black plastic part. It is held down by a bunch of 10mm bolts. remove the fuel line and the big black injector harness connector(1 tab on each side) and its pretty self explanitory from there. Make sure you lube up the rubber seals when going back together it will make it easier to slide back on. You will understand once the upper plenum is removed
Old Jan 31, 2004 | 06:11 PM
I bought a repair manual today and i see what your talking about now. It looks like you have to take alot apart to do it, will I need any new gaskets for the upper plenum to lower connection? Thanks agian!
Old Feb 1, 2004 | 09:02 AM
LS1NOVA's Avatar
The gaskets are reusable but a new set would be a good idea. The gaskets come in a kit through gm. Its packaged in a big white envelope. Just ask for upper plenum gasket
set.
Old Feb 3, 2004 | 07:11 PM
the verdict is in! Checked the fuel pressure the way l82ofast said and it was the pump. New pump in, problem is fixed and it starts perfect now! Pump was only $135 and $8 for the strainer and it was an AC delco part. Thanks agian for the help guys it is much appreciated.
Old Feb 3, 2004 | 07:49 PM
LS1NOVA's Avatar
Good fix, and good price on the part.
Old Feb 4, 2004 | 05:51 PM
25thhawk's Avatar
I have pretty much the same problem with my truck, how hard is it to put a fuel pump in? I really am hoping it is the regulator though.
Old Feb 4, 2004 | 06:31 PM
not bad depending on where you have to work on it and how rusty it is underneath there my truck is like brand new underneath and I have a lift so it only took a couple hours.
Y2KLimited
Dec 5, 2015 09:57 AM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
