Need help FAST please
Old Jun 13, 2005 | 07:12 PM
white1's Avatar
Default Need help FAST please
I just got my cam in. Its pretty small. 206/212 with 112 lsa. I cant get my truck to idle at all. I had the tune tuned for this cam. Did the tuner mess up? I put the new PCM in and did an idle learn a couple of weeks prior to doing the cam swap could this be my problem? I really don't want to drill my tb. Any suggestions? Thanks
Old Jun 13, 2005 | 07:19 PM
FILE's Avatar
Adjust the idle at the TB untill you can get your tune figured out.
Old Jun 13, 2005 | 07:23 PM
white1's Avatar
Just drill a bigger hole in it?? By the way thanks for the valve springs.
Old Jun 13, 2005 | 07:31 PM
FILE's Avatar
No... don't drill any holes... There is a screw in your TB that you can move to adjust the idle. This should not permanent. It's only to get it to idle and drive around while you get an update for your pcm to get it to ide.
If I am not mistaken this screw is called the set screw.
Old Jun 13, 2005 | 07:32 PM
white1's Avatar
Thanks.
Old Jun 13, 2005 | 07:43 PM
yackowski's Avatar
I would definitely try the set screw before I drilled any holes. I know when I did mine it fired right up without any adjustments to the tune. Drove it for a couple days with no problems at all. However* when a buddy of mine took my negative battery cable off as a practical joke, it went nutz and couldnt find an idle for like an hour of re-learning.
budhayes3's Avatar
PT's Slowest Truck
Just curious how it runs off idle, can you get it going if you drive with two feet?
Old Jun 13, 2005 | 08:07 PM
white1's Avatar
Yea I was able to get it going off of two feet. I drove down the road, killed it came inside to ask ya'll. Tried to call the tuner went outside to pick up and give this thread a little time said what the hell, and was able to do an idle learn. Thanks yall
Old Jun 13, 2005 | 08:31 PM
yackowski's Avatar
Good deal man, get some miles on it and tell us how it feels!
Old Jun 13, 2005 | 10:01 PM
white1's Avatar
Feeling better every mile. I went and drove around a little. at first it would try to die when slowing down for a red light, but it seems to be getting better. It idlels about 500-550 rpm Also sounds louder at red lights. Or maybe its just the lope
murderedSS
27
Oct 12, 2015 11:13 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
whitelazer
Sep 22, 2015 09:38 PM
