Need help for engine rebuild!!!
Old Apr 22, 2013 | 11:35 PM
spoolinbee's Avatar
Exclamation Need help for engine rebuild!!!
hello to all! i have a 2001 gmc rcsb 2wd with a iron head 6.0 and a 4l80. Im currently in the process of tear down on the engine and was wondering if this re-ring kit on ebay would be adequate for the rebuild. When i got the truck it had a rear mount turbo rigged up that i have removed. The engine had a lot of blow by and would push oil out of the dip stick tube. im hoping the rebuild will solve that issue. I have a tight budget of 1000 dollars to get the stuff for the rebuild and a tune. The plan is to hone the block and polish the crank and replace all gaskets. Let me know what you guys think about this kit.
Engine re Ring re Main Kit GMC Yukon Sierra 364 6 0L V8 LQ4 LQ9 2004 2006 | eBay
p.s. i plan on adding some boost later on down the road but nothing crazy.
Old Apr 22, 2013 | 11:39 PM
2doorfury's Avatar
1000 ain't gonna cut it..gaskets are expensive. A ring kit is150 alone. Head gaskets are 100-200. Intake gaskets are 75-100. Front and rear engine cover gaskets are 30 a piece. You'll have 1000 just in a rebuild.
Old Apr 23, 2013 | 12:12 AM
spoolinbee's Avatar
Well that adds up to about 510 not counting machinework. Lets say its 10 bucks a hole to hone and about 40 to hot tank the block and about 40 to polish the crank thats still under 700 dollars. I guess the tune can wait a week or so.
Old Apr 23, 2013 | 04:24 AM
2doorfury's Avatar
The gaskets I listed are just a few off the top of NY head.. I had about 350 just in gaskets and seals.
Old Apr 23, 2013 | 04:27 AM
2doorfury's Avatar
The local machine shop honed, hot tanked and installed the cam bearings, them supplying the cam bearings, all for 200. So machine work will be fairly cheap
Old Apr 25, 2013 | 12:39 AM
spoolinbee's Avatar
im thinkin i can get away with the rebuild at least for 1000. what do u think about the kit i found on ebay?
Old Apr 26, 2013 | 11:44 PM
spoolinbee's Avatar
anybody have any input???
SleeperGMC
Jul 29, 2015 10:22 AM
Ketis
Jul 23, 2015 12:37 PM
JordanH
Jul 14, 2015 03:46 PM
4B11T
Jul 13, 2015 03:48 PM
zaathur151
Jul 6, 2015 10:57 PM
