Need help diagnosing(sp) engine problems
Old Jul 7, 2005 | 07:04 PM
goshawk23's Avatar
Truck addict
Default Need help diagnosing(sp) engine problems
This is for my TrailBlazer 4.2L....
Problem, engine loses power when gas tank gets to quarter of a tank. (however it has occured at half a tank) If you try to push the pedal more than lets say 2 percent of travel, it will cause backfire and popping in the exhaust and not accelerate. if you keep it at that 2 percent area it will maintain a 10 to 20mph speed. It will stay this way till i fill up with gas.
So as i am traveling down the road it will be running perfect then all the sudden it feels like someone has turned the motor off and i am coasting. engine stays running but has no power at all.
I have changed the front o2 and have ordered plugs from the dealer but they won't come in till monday. Also, it has a relatively new fuel filter.
at this point, i am thinking these could be the culprits
1. the fuel pump is going out.
2. the cat is clogged.
3. i need to run it into a river.
4. some other ghost
Old Jul 7, 2005 | 08:05 PM
BigBlockChev572's Avatar
4. some other ghost
Also, popping/backfiring with loss of power means your timing is off, but it doesn't sound like it in this situation.
Philip S.
Old Jul 7, 2005 | 08:24 PM
goshawk23's Avatar
Truck addict
thats what it almost feels like when the power loss occurs. i can be driving down the Istate doing 70ish and everything is good, then it will just do it. feels like a 6 cyl on 4 cyl's. worse actually.
i wonder if the computer is bad?
Old Jul 7, 2005 | 08:58 PM
Ruffrider5.3's Avatar
Is the fuel filter in the right way? There is only one way it is supposed to go. It could be a fuel pump also. Check that the mass air meter is ok, sometimes they get crap on em and they will act all f'ed up.
Old Jul 7, 2005 | 09:21 PM
goshawk23's Avatar
Truck addict
fuel filter is in the right way. the lines are on the same end and clearly marked. this engine don't have a mass air sensor. intake straight to the throttle body.
if it was a cat converter, it would do it all the time right? at least i would think so.
i am leaning towards the fuel pump. considering it does it when the fuel level gets low. either that or my fuel level switch is bad and i am getting false fuel level readings.
Old Jul 7, 2005 | 10:31 PM
budhayes3's Avatar
PT's Slowest Truck
Seems most probable to me...
Old Jul 7, 2005 | 11:38 PM
Okie5.3's Avatar
pick-up tube loose, corroded 1/2 or further down, sediment build up in the pre-filter, etc...
ferrellrooster
Mar 6, 2025 03:22 PM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Mzay
Jul 6, 2015 11:03 PM
