NEED HELP ASAP with radiator
Old Aug 27, 2004 | 03:39 PM
gcooper's Avatar
Default NEED HELP ASAP with radiator
I'm tryin to pull the radiator but can't seem to get off these damed tubes. Already pulled off the e-clips anything else im missing. Thanks for the help.
This hose
Old Aug 27, 2004 | 03:50 PM
those are tranny cooling lines take it easy with those id spray em with wd 40 or something then line wrench em off work them back and forward
Old Aug 27, 2004 | 04:51 PM
Flyer's Avatar
There is a black plastic prtector on them, then there is a metal clip on there. Once the metal clip is removed, the lines should pull right off. It may take a little wiggling to get them removed.
Old Aug 27, 2004 | 05:04 PM
XLR8NSS's Avatar
Adkoonerstrator
There is a little clip tool you need to get those out. It's almost like the fuel line removal tool. You should be able to get one at any auto parts store.
You can also just take the fittings loose outta the radiator like Die4Bowties mentioned.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Tigger Welder
Oct 1, 2015 08:41 AM
old motorhead
Sep 29, 2015 08:22 PM
GM1697
Sep 28, 2015 08:28 PM
