Need Help ASAP!
Old Jun 23, 2007 | 09:20 AM
Toaders's Avatar
Default Need Help ASAP!
Guys my motor started rapping really bad last night. I have a 2000 chevy silverado with a 5.3. I found a 6.0 out of a 2005 3500 with 29xxx miles. will this motor be a direct bolt in? the place closes at noon so please help
Old Jun 23, 2007 | 09:28 AM
The 6.0 is a direct swap,if it uses a 4L80E trans you'll need to remove the crank spacer and use your original flex plate.You will also need to use your original intake and fuel rails because the 05 has a returnless fuel system.
Old Jun 23, 2007 | 09:31 AM
Toaders's Avatar
So I could use the intake manifold off my truck and flexplate correct? Thanks for responding quickly
Old Jun 23, 2007 | 09:47 AM
Yes,you can use your intake and flexplate.Good luck,keep us posted.
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
