need help with 6.0
Old Apr 11, 2007 | 09:40 PM
mguthr1's Avatar
Default need help with 6.0
alright guys, i just bout a 6.0 complete motor with a tr220 cam, and some 4.8 heads that were milled .30 over and a 3 angle valve job......now i got this out of a friends truck, but there is a cracked piston and a bent valve, what would have caused this and do you think it is even enough to salvage or should i just sell it. and also would this have any effect on the crank journals..........thanks and any information would be appreciated.
Old Apr 11, 2007 | 09:46 PM
blake2kz71's Avatar
hmm did he ever spray it? It can more than likely be fixed. Get it bored and build a solid 408 out of it. Then get some good heads wcch(sponsor), texasspeed(sponsor), or get some ok 6.0 heads for better flow and have them milled.
Old Apr 12, 2007 | 08:00 PM
mguthr1's Avatar
what about the milling, i know it brings the dome closer to the piston to increase compression, do you think that that.30 could have brought it that close and made the valve slap that piston and crack it.......... or would it have something to do with my rods or springs or etc.
Old Apr 12, 2007 | 08:51 PM
Tootall's Avatar
depends on the lift of the cam . . . was that the only cam in the engine? . . . what springs were on the heads, and how old/miles were on them?
You could have broken a spring, and the valve dropped far enough to get slapped.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
