Need help
Old Sep 18, 2016 | 02:52 PM
rudvirus's Avatar
Default Need help
Just put in a 6.0 the mechanic said my throttle body is bad it work before the swap. It's having trouble idling before and after a tune. It was a stock 5.3 throttle body and now it's on a 6.0 does that make a difference. If. Need a new one what other one can I put on for more air flow I have a 8 pin connection on my throttle body. It's a 05 ECSB I do plan on putting on a pro charger as well. It's really bad when you put it in to drive or reverse. Or when you come to a stop.
Old Sep 18, 2016 | 04:06 PM
FFDP's Avatar
It doesn't matter that the TB is on a 6.0 now.
I'd just stay with a stock TB, they work fine for a turbo cars and prochargers. The opening of the factory intake isn't getting any bigger so the TB doesn't have to be. The air being shoved in is under pressure and the stock TB size won't hurt anything.
Old Sep 18, 2016 | 11:53 PM
Atomic's Avatar
I have a gauge for that
Did you adjust the tune for the larger engine? If not there's your problem, you need the pcm reprogrammed for the larger engine.
Mctowns24
14
Oct 5, 2016 10:37 AM
CanadianVRss
Sep 22, 2016 02:33 AM
Ryan Mills
Sep 19, 2016 11:04 AM
Cakes
Sep 18, 2016 12:56 PM
TXsilverado
Sep 15, 2016 01:11 PM
