need help!!!!
Old Aug 25, 2008 | 04:15 PM
icedenali's Avatar
Default need help!!!!
my truck has kind the hard time starting sometimes but it turns over. but when i tap the gas hard it dies on me, but when i press gas slow it has little hesitation but rpm goes up. could this be fuel pump related problem?
i just change map sensor. and is still same.
its been doing it for about 2 weeks now i havent really drove truck a lot but this is driving me nuts. i check with my tuner and he think is not tuning because i had tuning over 3yrs with out n e problem and i dont think tune can change itself all of sudden.
fuel regulator or pump or fuel filter? if so how do i check it?
help guys!
Old Aug 25, 2008 | 07:42 PM
m3srt's Avatar
Banned
i 've been having this same problem i took my truck in to the dealer and they said its a bad fuel pump , not enough pressure or something like that my symtoms are .. extended crank . . but once its fired up its fine ..
Old Aug 25, 2008 | 08:18 PM
GMCtrk's Avatar
You could hook up a fuel pressure gauge and check it.
Old Aug 25, 2008 | 08:47 PM
icedenali's Avatar
i was thiking fuel pump too i have extendend warranty but i dont kno if dealer will fix it with warranty. or if not i have to change it on my own.
thanks guys i will check pressure tomorrow
Old Aug 27, 2008 | 06:53 PM
brent1976's Avatar
11 Second Club
On e of the service trucks at work was doing the same thing and after I did a fuel pump I figured out it was the fuel pressure regulator.
Old Aug 27, 2008 | 09:48 PM
icedenali's Avatar
OMFG guys it turn out to be spark plug wires. i couldn't believe myself for one last try i change to new wires and plugs and its cured
thanks for all ur input guys.
no more stall and runs strong as it used to run.
Old Aug 27, 2008 | 10:29 PM
GMCtrk's Avatar
damn, all these problems and it was just bad plugs. Should have checked that first I guess since they're so cheap. Glad your up and running now!
Old Aug 27, 2008 | 11:42 PM
icedenali's Avatar
yea man it was bad plug wires hahahaha can't believe myself either. but thanks y'all.
