need headers/ what is a good set
Old Jul 4, 2006 | 06:52 AM
tommytahoe's Avatar
Default need headers/ what is a good set
i have 98 tahoe i want to switch to some performance header for more power ...the one on the truck r fine but they are cast and look ugly ....and weigh a ton..
Old Jul 4, 2006 | 07:47 AM
Thumbs up
Dynatech LT's w/ cats. High quality fit, finish, and all stainless steel. Full bolt-on kit, NO WELDING or FABRICATING REQUIRED! Bolts right up to your O.E. or aftermarket cat-back system.
They're not cheap, but they among one of the best kits in the market.
www.dynatechheaders.com
Did a quick search, they may not make a set for your model year. You will probably have to call them to see.
If not, Pacesetter may have something for you.
Note: do not use shorty style headers, they do not give you much HP gains to vouch for the money spent. Maybe 3-5 hp.
Look for LT (long tube) style headers.
Jim
Old Jul 4, 2006 | 08:39 AM
Scott Mills's Avatar
Reference this thread, it has some usefull information about headers.
https://www.performancetrucks.net/fo...d.php?t=368126
Old Jul 4, 2006 | 03:44 PM
hog's Avatar
hog
I am using Hooker Competition Series Long Tube headers pn 2462 1HKR ceramic coated, 1 5/8" x 2 1/2". I got a bunch oif low rpm torque and power all thru the rpm range. For painted steel, $180, ceramic coated $330 and stainless steel $550.
If you are in an emissions tested area, you will need to weld a bung in 1 of the primary tubes on the drivers side to supply the EGR.
You will need to get the muffler shop to weld up some headpipes(connect headers to cats). I used dual 2 1/2" stainless tubiing instead of teh restrictive 1 7/8" stock headpipes that crimp down even smaller in some areas. I am also running dual 2 1/2" cats.
Hooker also makes a 1 3/4" primary x 3" collector Super Competition Long Tube, its pn 2806 $400 for painted, $700+ ceramic coated.
the Competition series just drop right in where the Super Comp series need some engine jacking. James B is using the 2806 Super Comps on his 99 OBS Tahoe.
peace
Hog
Old Jul 5, 2006 | 07:46 AM
Avalanche2002's Avatar
You're going to get a lot of recommendations for Pacesetters here.
If I was doing it, I would go with a complete Dynatech setup. That's what I've got on my Vette. Don't waste your time on mild steel as they require upkeep and will eventually rust out (I had a set of Edelbrocks on my Sonoma and they rusted out in 10 years), go with stainless.
JordanH
Feb 28, 2017 07:22 PM
Raggedz71
Jul 29, 2016 10:20 AM
hartinclay
Aug 2, 2015 06:44 PM
maxspeed05V
Jul 19, 2015 07:08 PM
gavin2005
Jul 16, 2015 12:09 AM
