need head...advice
Old 08-16-2014, 09:39 PM
greasemykey's Avatar
Default need head...advice
so i broke a spring on my POS PRC heads and i am going to scrap them. who makes a better head for my 383? i have looked at WCCH, PRC, Edelbrock, and AFR. am i missing any others?
Old 08-17-2014, 03:48 PM
GM_Devil's Avatar
trick flows gen X
Old 08-17-2014, 04:27 PM
TXsilverado's Avatar
Tea, advanced induction, trick flow
Old 09-01-2014, 07:00 AM
what do you guys think about the AFR 225cc LS1 heads?
Old 09-01-2014, 10:06 AM
JohnDaMan's Avatar
Mast. Those are the best
Old 09-01-2014, 01:04 PM
Afr is another big name. Wouldnt mind trying a set myself.
Old 09-01-2014, 05:28 PM
ill be buying a new set in a few weeks. going to pull the heads soon and see if there is piston damage. If so I need to order 1 new slug. will I need to balance the rotating assembly again or can I swap the piston and install a new set of rings and be ok? I will also be lowering my compression from 11.5 to 10. I think 11.5 is a bit to high for a street engine. opinions?
Old 09-01-2014, 06:31 PM
another comp cams failure. i think i may rebuild this head and install new springs. what company should i use for springs? im thinking ISKY. they always did well by me. just hope it didnt damage the piston. the valve is bent so i know there was contact. **** me running.
Old 09-01-2014, 06:55 PM
low2001gmc's Avatar
PSI and PAC Springs are best in my books. Never have heard or read of issues with them...
Old 09-01-2014, 07:08 PM
hey how is the LSXRT treating you?
