Need cats!!
#71
With this as my crossover to free up sone space over the trans xmember.... The lighter colored pipes are my factory y pipe, the darker are a part of a ypipe i got couple days ago off a tahoe at a scrap yard.... Thinking it will accomplish two goals at once, crossover and a quick easy way to unbolt the pipe for trans removal etc!! Think the open area between the two y's is about same distance as the x in my camaro's exhaust
#72
This is my plan for cats and my LTs.
Magnaflow 59956 high flow spun cats are 2.5" inlet/outlet and are 8" long. I'm going to cut them down 1.5" on each end, that will shorten them by 3" inches for a total length of 5" and give me the 3" inlet/outlet diameter needed for my 3" exit and exhaust.
Not the best pic but you can see how much will be removed to give me the 3" inlet/outlet
#73
So they are 8" overall length??? My problem is that i need the 3" for the vbands, how are you attaching them to the crossover pipe?? I want to be able to unbolt the cat pipes or ypipe to be able to swap trans etc without having to cut it every time..... if i could find a 3"inlet to a 2.5 oulet cat that would be optimal... Like my exhaust right now and consodering the length of the pipes, 2.5 is fine, as far as i can tell!!! If i ever do what id really like to and have pipes exot in front of rear tires, i will go 3" at that point but for now i like the way its run just seriously thinking about either ordering a set of tailpipes (dynomax and i saw them somewhere else prebent, magnaflow or flowmasters website i think) or just sayin screw it and having another driver pipe bent passenger side pipe is damn near perfect, its driver side i have issues with, wouldnt even be opposed to dual same side exit!!!
#74
Yes, they are 8" overall. After being cut down, they'll be 5" overall.
You should be able to get 3" V-bands for them.
Well, this is the beginning stage as I am just starting to put this on paper while I get my block prepped and built.
I will more than likely weld them on to the y-pipe and v-band to the header.
You could always do what I'm doing but only cut one side down to get you the 3" inlet and 2.5" outlet.
#75
Unless im missing something the vbands need to have a flat surface to mate to, as i understand it one side would be extended slightlybthrough the band the other would be recessed into it the same distance, so the pipes are end to end inside the band!!!
#80
I know, you'll have to inquire with them. That was the first image that popped up when I googled it.
Typically when they don't advertise the price, its going to be expensive.
I know Burns has some male/female v bands for about $85 a set. That's about as good as it gets in the exhaust world.
