Need Assistance-No Heat
Old Dec 1, 2004 | 08:25 PM
BINNCZ71's Avatar
Default Need Assistance-No Heat
1999 ECSB Silverado Z-71 ..
5.3l
Getting no heat inside the cab.
Suspect its the thermostat.. The lower Radiator hose
is cool to the touch, whereas the upper rad hose and the hoses to the heater core are warm..
sound right?
Swapped out the control unit that controls the fan speed/ac temp setting with a good one, no change.
Thanks for any input..
Old Dec 1, 2004 | 08:51 PM
KeukaZ71's Avatar
is the heater/blower fan working?
Old Dec 1, 2004 | 09:01 PM
BINNCZ71's Avatar
Yep..
The blower fan runs at all speeds, the AC works great, no heat.
Old Dec 1, 2004 | 09:45 PM
chevymec's Avatar
What temp does the truck run at??
Old Dec 1, 2004 | 10:03 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Put another jacket on and dropped a hot pocket in your pants!
Old Dec 2, 2004 | 07:32 AM
BINNCZ71's Avatar
Truck runs at normal, does not heat up.
Suspect thermostat has stuck open.
Old Dec 2, 2004 | 06:38 PM
chevymec's Avatar
If its runs ok, and it doesnt heat up then Id say your right, get a thermostat for it
Old Dec 2, 2004 | 06:48 PM
BigTex's Avatar
Even with a stuck open tstat, its going to warm up. It may not get HOT, but it will be warm. What temp does the truck run at? If the gauge shows near 200, its not your tstat.
Old Dec 2, 2004 | 07:46 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, I agree with what BigTex said. You also mentioned that both heater hoses were hot...that would dictate that your heater control valve is working. May have a stuck blend door or siezed blend door actuator.
Old Dec 2, 2004 | 07:51 PM
Black02Z71's Avatar
Has the cooling system been work on lately, you could have an air lock. And is the coolant low at all.
