Need an answer quick!
Old Jul 13, 2003 | 03:17 PM
Default Need an answer quick!
Well i took my throttle body off so i can drill a hole in it so i can smooth my idle out with my new cam. (216/220)still waiting on tuning. i was told to put a 9/32 hole in it, but i discovered there is a hole in the blade already?? is there supposed to be? im not sure how big it is but i know its smaller than 9/32. so should i just drill the hole out bigger or make a seperate hole on the TB???thanks
Old Jul 13, 2003 | 03:24 PM
whitez71's Avatar
Default Re: Need an answer quick!
Drill out the hole that is already their. Drill it out a little at a time, can't put any metal back if you go to big.
Old Jul 13, 2003 | 03:27 PM
GREGGO's Avatar
Yes, the hole is suppose to be there. Listen to what whitez71 said though, good advice.
BlownChevy's Avatar
blownerator
25 Year Member
Ditto.
Old Jul 13, 2003 | 03:28 PM
so do u think a 9/32 hole is to big?
Old Jul 13, 2003 | 03:49 PM
whitez71's Avatar
I,m not sure what size the hole is. I would just measure the hole with a drill bit and see what size it is. Grab the next size bigger bit and drill it out. Stick the TB back on and see how it runs. I would only go a couple sizez larger and if still idled bad wait for the programing.
Old Jul 13, 2003 | 04:05 PM
gonzo 6.2's Avatar
Since you have the TB off,take out the throttle stop or idle screw and switch it to the top side,it's a small torque,do this and you will have your adjustment were you can get to it on top.I drilled my plate slightly adjusted the screw just a little and Ed Wright Adj. the idle up 50RPMs mines perfect at about 675RPM idle
Old Jul 13, 2003 | 09:58 PM
silent1's Avatar
Like I said in your other post, I have that cam and that is the hole size that really made the difference for me. I went little by little and that's the size I came up with. You can't go wrong with doing little at a time. Just some advice though, make sure your drill bits are SHARP and have a steady hand. If that blade cracks you can only buy the entire throttle body now. Good luck.
Old Jul 13, 2003 | 10:01 PM
silent1's Avatar
One more thing, you'll need to bump your idle to 800RPM's for best idle quality. Do it via the throttle blade set screw or tuning.
Wrecker 426
Oct 7, 2015 12:11 PM
sTNT971
Sep 26, 2015 06:27 AM
chevstang421
Sep 10, 2015 09:16 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
