need aftermarket head help with 4.8
Old May 8, 2008 | 05:26 PM
chevybowhunter's Avatar
Default need aftermarket head help with 4.8
best heads for little 4.8L?
Hey guys i need some help please. i have a 4.8L in my truck. i have LT headers, custom tune, CAI, throttle body on there now. i'm going to replace heads due to already purchasing a new cam and other problems. about a week ago my top end started knocking very badly. i don't know if it is bent pushrod, loose rocker, bent valve, etc... i already have the cam, roller rockers, and pushrods. i just want to go ahead and replace the heads for the knocking and performance reasons. can someone tell me what heads would work good i.e... 243's, ls6's, etc... i have no idea what the 4.8 has for compression ratio either. any help with head info, gasket sizes for higher compression, etc is very, very much appericiated.
Old May 9, 2008 | 10:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The Problem with a Larger head like a 243 is that it is designed for a larger bore. It will lower your compression and you will lose power unless you mill them down. Then you will need special pushrods.
I Personally am looking at a set of WCCH Stage1 Hand ported heads for my own 5.3L . Also Texas Speed and Performance has some heads for the 4.8L/5.3L Check out this disscusion were having. Good luck.
https://www.performancetrucks.net/fo...d.php?t=417385
JordanH
Aug 8, 2015 07:59 PM
sauldgold
Jul 23, 2015 02:15 PM
bk_cauley
Jul 8, 2015 05:37 PM
