Need advice for cam/converter in CCSB!
Old Jun 9, 2012 | 07:24 PM
VegasJ's Avatar
pretty much the same truck as mine!
I'm curious to what you go with, cam/stall is next on my list
Old Jun 9, 2012 | 07:54 PM
Whitecrewcab's Avatar
I have a 218/224 on a 110LSA cam waiting for mine. The truck has a 3000 9.5" Vigilante in it already. I went ahead and got a TBSS intake and a 90mm throttle body to go with it when I finally get the time to get it all installed.
Old Jun 9, 2012 | 08:04 PM
jrmchevyman's Avatar
Should be a good combo you have going. Post some vids when you get it all installed.
Old Jun 10, 2012 | 12:15 AM
grey matter 04's Avatar
13 Second Truck Club
212/218 will work much better In your truck than a tr220
Tr220 lacks lowend torque
I ran both the 212/218 and tr220
Old Jun 10, 2012 | 12:21 AM
texasglock23's Avatar
sub'd as I am on the fence too
Old Jun 10, 2012 | 02:49 AM
pewterliftedz's Avatar
grey u weren't running enough gear or converter for that tr220. 220 or 224 with a 9.5" 3600 will be fine with his 3.73s.
I say 220 if your going to keep the stock 862.
224 if your planning on upgrading to either worked 862s or milled 243s.
a NNBS intake with a 90mm TB will be another upgrade for later.
Old Jun 10, 2012 | 09:07 AM
jvoisel's Avatar
Heads will definitely be next in line, as well as probably a tbss intake.
Should I keep my current corvette servo or change it out for the fairbanks servos?
Old Jun 10, 2012 | 09:35 AM
SloStepSide's Avatar
Agreed, the 220 is to sluggish down low. If I could redo it I would go with vincis trucker cam.
Old Jun 10, 2012 | 04:07 PM
jvoisel's Avatar
Found a 6.0 and 80e local from two different people, so will be looking into both now too.
Old Jun 10, 2012 | 04:22 PM
ltr450ryder's Avatar
6.0/80e I would do then u can get Ur 224 with no problem or even a 224/228
