Need adj. rollers that I can keep the valve covers with?
Old Mar 14, 2005 | 12:51 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default Need adj. rollers that I can keep the valve covers with?
Anyone have any ideas?
Old Mar 14, 2005 | 01:21 PM
BurnOut's Avatar
I have some 1" valve cover spacers that I'm selling that will allow you to run whatever rocker you want... all you'd need after that would be longer spark plug wires.
I also have a set of (slightly) used Jesel MoHawk rockers that I am looking to sell.
Old Mar 14, 2005 | 01:36 PM
marc_w's Avatar
I can't say whether or not they'll fit with all that lift, but I will definitely put in my recommendation for the VHP/Crane rockers. You'll be around .607" with the 1.79/1.7's.
I didn't have to mod my covers to run my 1.89's to ~.568" at the valve.
Old Mar 14, 2005 | 09:43 PM
silent1's Avatar
Comp Pro Magnums.
Old Mar 14, 2005 | 09:54 PM
mattrem's Avatar
Erik, I have Harland Sharps on mine, they are non-adjustable but are close to the valve covers. I say the Comp rockers with a spacer for the covers and a set of MSD wires they should be long enough to add the valve cover spacer. The MSD wires are almost too long, the number for them are 32829 I think. I think Comp makes a great rocker, its all I ever used on the oval track car and never had a failure.
Old Mar 14, 2005 | 09:55 PM
I'm running 1.75 Comp Pro Magnums,with spacers I bought from TEA.I've been told that they will fit with a little trimming of the baffle inside the valvecover.Why do you need an adiustables,are you using Comp R lifters and need to adjust the preload or what?
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
USMCvet0311
Sep 4, 2015 09:43 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
jtphelps289
Sep 1, 2015 08:58 PM
