Nbs 6.0 to nnbs?
Old Sep 2, 2010 | 02:26 PM
urdone's Avatar
Default Nbs 6.0 to nnbs?
Hey guys sorry for this question but im new to this. I want to insert a 6.0 from a 2003 chevy to a 2009 chevy. What shoud I need to do?
Old Sep 2, 2010 | 05:06 PM
urdone's Avatar
Anyone...
Would everything fit but the knock sensors, what can I do?
Old Sep 2, 2010 | 05:20 PM
1Bear's Avatar
Read everything you can about putting a Gen IV in a Gen III equipped vehicle and reverse it. The main problem is Lingenfelter makes a converter box to convert the 58X crank signal to the 24X signal the ECM requires and as far as I know, there is nothing out there to do the opposite. It would appear the answer would be to pull the crank to have a 58X reluctor wheel installed and then everything would be pretty basic from there on.
Old Sep 2, 2010 | 05:46 PM
LightFighter's Avatar
Oh a Gen III swap into a Gen IV you need to relocate cam sensors.... the make a harness for that........... like 1bear said I don't know about converting 58x to 24x signal........ but I'm sure its been done ......... but you might have to change the crank and cam timing gear........... at that point you should just get a Gen 4 motor
Old Sep 3, 2010 | 09:41 AM
urdone's Avatar
I will hgave to see that. I kniw its been done out there, but I dont have a clue whgat I need to do
Old Sep 3, 2010 | 10:18 AM
iamkeniff's Avatar
if you already have a 07+ GMT900 find a short block from that year. it'll be cheaper vs pulling the crank, putting a 58x reluctor ring, swapping to a 4x timing gear, drilling the side of the block to put the knock sensors. its easier to put a 58x into a 24x bc you can just add a harness, add a 58x to 24x conversion module.
natejk
Nov 15, 2016 08:05 AM
mitchellmade
Sep 27, 2015 08:27 PM
Gmc_sierra
Sep 13, 2015 10:02 PM
chvy=power
Sep 8, 2015 11:06 AM
