narrowed to four cams.. which one?
Old Jul 11, 2004 | 12:41 AM
derek_silvy's Avatar
Default narrowed to four cams.. which one?
I think I have narrowed it to three cams, and need help deciding which one would be best. I don't want the engine to have to reach very high for power, I want there to be no tuning required, and of course, I want GAINS!
The cams I am choosing are based on price (I can get all of them used for less), but also with the understanding that they will all yeild some gains somewhere in the powerband.
Early LS1 cam:
209ex/198in duration, .5/.5 lift, 119.5 LSA
Late LS1 cam:
207ex/198in duration, .479in/.467out lift, 116 LSA
LS6 cam:
218in/204ex duration, .550 lift, 117.5 LSA
LPE GT2 cam:
205in/212ex duration, .540 lift, 116CL
And, just for reference, the stock 99 5.3 cam:
191in/190ex duration, .466in/.457 out, 115.5 LSA
Help me here guys....
I know these cam questions get old, but do I appreciate everyones help.
Old Jul 11, 2004 | 02:00 AM
Hit Man X's Avatar
Early LS1 cam:
Late LS1 cam:
LS6 cam:
LPE GT2 cam:
In order of the cams...
NO
Maybe
NO w/o stall
Better than no 2 choice but more costly.
To get the best of either the late LS1 or Lingenfelter cam tuning will help...
Old Jul 11, 2004 | 06:00 AM
GREGGO's Avatar
If you want the least amount of tunning, I would go with the 01 LS6 cam. Here are some numbers for you.
-2001-2002 LS6....204/211 .525/.525 116
Part # 12560950
-2002-2003 LS6....204/218 .555/.551 117.5
Part # 12565308
Old Jul 11, 2004 | 08:17 AM
one03sierra's Avatar
Formerly one92rs
Talking
you can do those cams for less but imo will be dissappointed with the results. i went to a 99 f bod cam and it was ok. i think there are other mods you can do that will yield more power. all the cams you have listed will lose some low end. what are the mods you have now.
Old Jul 11, 2004 | 11:46 AM
Hmmm, I will lose low end with ALL of those cams?
To answer your question as to what mods I have already:
K&N FIPK, Pacesetter shorties, removed cats, Dynomax ultraflow dumped before the axle, and a vette servo...
That's it as far as performance goes. I could do a tune now, but that would be stupid if I am going to turn around and do a cam two months later, and I don't wanan do a stall yet.
Old Jul 11, 2004 | 12:00 PM
Formerly one92rs
Talking
well if you have already removed the cats then you prolly have losdt some low end already. i suppose you wont lose to much more. but you will gain from 3000 and up and be able to move up the shift points.
Old Jul 11, 2004 | 12:54 PM
mudz5.3's Avatar
[ I could do a tune now, but that would be stupid if I am going to turn around and do a cam two months later, and I don't wanan do a stall yet.[/QUOTE]
If you do a nelson tune then all you would have to pay for is the shipping cost which is 10$ and the cost of shipping the core back.
Old Jul 11, 2004 | 02:23 PM
Thanks for the advice guys! It helps a lot!
The GT2 cam deal isn't gonna work out, so that leaves those other cams.
If for 50 bucks + the cost of gaskets I could get an LS1 cam, and gain 15 horses to the wheels (I'm hoping, at least), than its not really a bad deal, is it?
Old Jul 11, 2004 | 04:05 PM
Hit Man X's Avatar
Depends on how valuable your time is...
Old Jul 11, 2004 | 04:34 PM
GREGGO's Avatar
What do you need gaskets for? I've puled the front end on mine 3 times without changing gaskets. As long as you inspect them, to make sure they are not seperated from the metal, cut or flat spotted they can be re-used. They are very durable. I mean since your on such a buget, that's a few more $$ saved. As for the crank bolt, you can use the same one over, but you better check it every few hundred miles for the first 3000. Mine came loose, but that pulley is not going anywhere.
