NakedAV here is my dyno sheet
Old Jul 28, 2004 | 12:40 PM
  #21
moregrip's Avatar
what a rush!
How fast does the radix turn on a 6.0 w/ the stock 3.1 pulley, lets call it at 6K rpm?
Old Jul 28, 2004 | 12:41 PM
  #22
moregrip's Avatar
what a rush!
How about this one, how fast does the radix turn on a 6.0 w/ the stock 3.1 pulley, lets call it at 6K rpm vs. the radix max rated rpm?
Old Jul 28, 2004 | 01:12 PM
  #23
Flyer's Avatar
THe RADIX blower is rated at 14k rpm's. I'm spinning mine at just a hair under 17k, some Lightning guys have spun them as high as 18k though. I think that should be about the limit though.
Use this as a formula to see what you're spinning the blower at.
8 * 6000 / 3.1
8 is the diameter of the crank pulley
6000 is engine rpm
3.1 is the diameter of the blower pulley
In my case it's like this:
8 * 6500 / 3.1 = 16,774
Old Jul 28, 2004 | 01:15 PM
  #24
moregrip's Avatar
what a rush!
I came up with 15,483. Is that right? seems way high to me though.
8 x 6000/3.1 = 15483, that would be higher than 14k stock, hmmm
Old Jul 28, 2004 | 01:25 PM
  #25
Flyer's Avatar
If you use 5400 which is what I think the Superchips tune sets the shift points at, it will come out to 13,935 rpms. That would work out about right. IF ... they do set the shift points at 5400 that would explain why they don't support the warranty if you do your own tuning.
Old Jul 28, 2004 | 01:27 PM
  #26
moregrip's Avatar
what a rush!
thanks flyer
brian, can you shed some light here? as to warranty parameters, max rated parameters, and actual usage parameters?
Old Jul 28, 2004 | 01:28 PM
  #27
F8L Z71's Avatar
Is anyone running 10psi+ on a 5.3L with the Radix? I am really curious how the curves compare to my turbo setup so I can better explain when giving advice to people on the street and at the track when they ask which is better. I wanna be able to give good advice based on their needs and not the typical "get what I got because it's the best" kinda crap.
I should have the new motor in and the bigger turbo on with less boost so we'll see how those #s compare. 10psi Radix and 10psi rear-mount turbo on a 5.3L. Cost is comparable and both are fun as hell
Old Jul 28, 2004 | 01:30 PM
  #28
Mr. Sandog's Avatar
8 * 6000 / 3.1
6000 is engine rpm
Hey Flyer - are you positive about the crank pulley diameter? And is it the same diameter for 6.0/5.3/4.8?
Old Jul 28, 2004 | 01:33 PM
  #29
Mr. Sandog's Avatar
Originally Posted by moregrip
thanks flyer
  #30
moregrip's Avatar
what a rush!
Originally Posted by BlownChevy
Should make 110-120 hp over the stock dyno numbers. ITs not even close to maxing the blower out.
with reference to this comment applied to the LQ4 if max radix rpm is in fact 14,000rpm, and if superchips shift point is 5400rpm, and a 6.0 crank pulley is 8", then the radix is shipped at max warranty parameters for the LQ4 kit.
i.e. 8 x 5400/3.1 = 13935.
