NakedAV here is my dyno sheet
#31
on another note if the radix is commonly operated up to 18k, I can still buy the 2.75 pulley and be OK.
8 x 6200/2.75 = 18036
if the lower pulley is actually 7.5" then
7.5 x 6200 = 16909
all things above holding true
7.5 x 6200 = 16909
#32
#33
F8L Z71, I can't answer that question completely, BUT, I can say blownchevy was running an LQ4 with a 2.8 pulley and upgraded heat x-changer with no problems.
I believe he was shifting at 5800rpms (remembering/guessing).
ergo 8 x 5800/2.8 = 16571
It might be safe to say, with the upgraded H/E and up to approx 16500 the radix is just fine.
I don't know what heat penalty there might be in the 16500 - 18000 rpm range though, but I bet the guys on the lightning boards know and brian
#34
I don't think the bigger issue is heat in the motor at those high of RPM's. I think that after 16k you would start having to worry about things staying together in there. 18000 rpms is spinning really fast.
#36
whats up with this?
Apten Performance Ported Eaton Supercharger
The Apten-ported Eaton blower has been causing a bit of a stir. The porting modification nets between 30-40 rwhp and the cost is $599. with exchange. I bought their ported blower mod and netted 38rwhp. A custom dyno tuned chip to match your modifications and a quick change pulley set are also available.
For an additional $495. Apten will polish the exterior of the blower. The price is $495. and the whole polishing process takes just over a week. For more info contact them at (314) 276-9608 or E-mail: info@apten-us.com
The Dyno Proof!
Below are pictures and dyno charts from one of our test vehicles. Thee tests were done in 90 degree weather and reflect real world gains. Our test car consistently made nearly 480RWHP with our supercharger, pulley, cat-back exhaust, and intake kit. If you consider those numbers are at the rear wheels, this motor is really making around 560HP at the flywheel! Those products give a combined HP gain of 180HP!
The Dyno Proof!
