My turn to ask a cam question
Old Jun 9, 2005 | 06:15 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
yes a 230 ought to do it but you dont think it will be too much? I have been thinking of getting my converter restalled to around 3500 while the engine is out would that allow me to go a little bigger?
Old Jun 9, 2005 | 08:10 AM
Originally Posted by storm5.3
He wants a choppy idle and a 6L is going to eat that up. I vote my favorite cam for a 6.0....TR230. That ought to make that 6.0 shake, rattle, and roll.
I agree the 6.0 will eat up a ton of cam, 230 for starters & maybe up from there, I have the same cam as thunder but on a 114lsa, There is no denying the presence of a strong powerful cam when I pull up. I vote go big! The thing about cams is we always end up wanting more
Old Jun 9, 2005 | 08:35 AM
BLACKND's Avatar
Yeah, thing you have to remember is that 01Thunder is running a 4.8, so that cam is huge in his truck. To get that same kinda reaction in a 6.0, you're gonna have to go big or go home. A cam in the 228-232 range should be good for what your wanting, but you might have to retall the converter.
Old Jun 9, 2005 | 08:55 AM
1slow01Z71's Avatar
Yeah right now Im leaning towards a 228 or 230 but what las should I go with 112 or 114 what is that going to change as far as how it runs. Im not very bright when it comes to cams so I dont know what changing the numbers is going to do.
Old Jun 9, 2005 | 10:31 AM
the tighter the lsa the more valve overlap that will occur, I chose the 114lsa for two reasons:
ease of tuning
I am running nitrous
Typically with a good cam selection the tighter lsa gives more n/a hp while the wider lsa will yeild more hp on the bottle this can also have the tendancy to move the power band up
Old Jun 9, 2005 | 11:39 AM
1slow01Z71's Avatar
Crazycutter how are you getting away with shot a 220 shot without grenading an engine. Sounds like I should go with a 114lsa. I want some good n/a hp but I want the nitrous to hit hard too. I will probably be spraying a 150 shot after its all said and done.
Old Jun 9, 2005 | 11:45 AM
moregrip's Avatar
what a rush!
Originally Posted by F8L Z71
Do you have the flow sheet from those heads? If not then I would talk to the people who designed the heads. A cam should be matched to the heads, not just chosen because someone said it worked well in his Uncle Rico's truck.
If you do have the sheet then you can fax it to other cam grinders along with your mods and plans for how you want to use the truck and they can come up with a good spec.
specs will be the same as my WCCH Stage 2 heads, with some slight variances of course.
Old Jun 9, 2005 | 12:33 PM
1slow01Z71's Avatar
Here are grippy's specs for his heads and mine are going to be almost exactly the same
Chevrolet 035 Casting 6.0L Heads
Ferrara 2.02" Intake Valve 1.57" Exhaust Valve
Bronze Guides
WCCH Dual Springs good for .650 lift
WCCH CNC Machined Titanium Retainers
GM Locks
Combustion Chamber 74.5cc
Intake Runner Volume 232cc
Exhaust Runner Volume 86.4cc
Flow Data:
Intake
.100 73.7
.150 114.9
.200 145.8
.250 185.8
.300 216.2
.350 240.5
.400 260.4
.450 278.9
.500 296.3
.550 308.0
.575 309.2
.600 294.4
.625 297.4
.650 298.6
Exhaust
.100 61.8
.150 97.4
.200 122.0
.250 153.5
.300 180.5
.350 197.9
.400 210.3
.450 218.2
.500 225.0
.550 226.8
.575 228.4
.600 230.1
.625 231.7
.650 232.5
Hopefully this will help everyone out on giving me some advice.
Old Jun 9, 2005 | 12:41 PM
Sport Side's Avatar
Were those heads flowed with an intake or a stub pipe on the exhaust?
Old Jun 9, 2005 | 12:46 PM
120 dry nos, tnt 100 wet two stage, actually still runs pretty rich. This is on the stock fuel system, I can't run more than 22 degrees of timing, afr was around 12.2 on the dyno, too scared to go any leaner. I have 29k on it now & at least 500 lbs of nos through it, still goin
