my poor 4l60
Old Nov 15, 2004 | 06:06 PM
Todd@AZPowerAndSound's Avatar
Default my poor 4l60
got a call back from the mechanic today. He listed a million things he did, but the things I remembered was replacing burnt/scorched 1-2 bands, and trashed 3-4 clutches. Guess I killed 4l60 purdy darn good.
Old Nov 15, 2004 | 07:48 PM
GOOD ****!!!! If you are going to blow it up, might as well do a good job. Well at least you can built the **** out of it now. Good luck bro and sorry to hear about the blown up tranny.
Old Nov 15, 2004 | 08:07 PM
Flyer's Avatar
I have a built tranny sitting in the shop if your interested. I'd LOVE to get rid of one of the 2 of them. PM me if you're interested.
Old Nov 15, 2004 | 08:08 PM
Flyer's Avatar
Expect that to be the norm if you don't do anything with it. The band and the 3/4 clutches are the weakest links. Did he replace the drum too? If not, the band will more than likely go out soon again.
Old Nov 15, 2004 | 10:04 PM
Last Call's Avatar
TOTM: January 2007
i guess mine lasted a little longer than yours, about 6 months. I burned up the 1-2 and 3-4 clutches. I stretched the band. The killer was the sprag that basically disentigrated. There was nothing left from it. I used the MagnaCharger warranty to fix the trans, but I still ended up paying a lot of money to get it back just to stock and not even built. After researching, I realized that the 4L80E is the only way to go if you want a reliable transmission that could holp up to 500rwhp. My transmission guy said that he didn't have confidence in the 60 lasting in the long run even with the best of parts. The design of the trans is the main problem. A new trans will be in the works before N20 and a smaller pulley. I hate breakin ****!
Old Nov 15, 2004 | 10:07 PM
Sorry to Hijack Why did you have to end up spending a lot of $$ if you had a warranty? Also How was your experience with them overall?
Old Nov 17, 2004 | 02:37 PM
14,000 miles =
burned 3-4 clutches and 2-4 band. reconditioned trans completely, replace clutches, replace burned and scored 1-2 band and drum, replace valve body. etc etc
Old Nov 17, 2004 | 05:01 PM
gonzo 6.2's Avatar
Did you do a servo?
they replaced one, but did not upgrade. Wasnt an option
Old Nov 17, 2004 | 06:36 PM
gonzo 6.2's Avatar
Im sure there was nothing wrong with the old servo,You need to get a upgrade servo in there before you beat on it. To bad the trans guy didnt drill the seperator plate and give a 1/4 turn to the force motor,that with a servo would help your trans life a ton.He should have done that as a minimum.Amazing the dealer covered it.
