My PCV ignorance. Help please
Old May 29, 2008 | 08:39 PM
Default My PCV ignorance. Help please
Ok, I'm told I do not have a PCV system in my truck and I really should. I'm also told I need a catch can. Problem is, I have not a clue where to even begin looking or what exactly I need to do. Anyone have some pics of the stock PCV location etc? Thanks in advance.
Old May 29, 2008 | 08:50 PM
2004SSS's Avatar
passenger side valve caover on the top of it near the front of the engine and back of the driverside valve cover . they are both hooked up to a vacuum on the intake , what you need to do is either cut the line or most likely get new lines and cleany routs it to the catch can.
Old Jun 2, 2008 | 07:39 AM
CHarris's Avatar
I ran both valve cover nipples to a t-fitting then to the catch can feeding into the intake vacuum fitting. I could stand to run two of the catch cans (one for each side), but since the inside of the blower was very clean with over a year of driving I think I'm fine.
I've got a brand new elite engineering can (in clearcoated silver) I'll trade you for some money off your convertor! I used to sell the elite cans before the manufacturer took away the profit margin
Old Jun 2, 2008 | 07:50 AM
i looked a little closer the other day. There is a vacuum line coming off the back of the driver's side valve cover that goes directly to the port on the blower. I didn't see anything attatched to it. I also found the vacuum line on the pass side valve cover. It was vented the intake tube but now it is vented to free air.
I think a catch can would be a good idea. shoot me a pic of what you have.
Old Jun 2, 2008 | 07:58 AM
there are 2 barbs on the blower just after the TB. they should be PCV, EVAP, and Brake booster. I have PCV and EVAP hooked up. Do I even have a brake booster?
There is also supposed to be a 4th barb on the TB which i do not have and that is where KB says to vent the pass side valve cover.
I like the idea of PCV and pass side both going to a catch can first then into the blower. yes, i like it a lot, lol
Old Jun 2, 2008 | 09:39 PM
BigKID's Avatar
You need to attach that pass side pcv line to manifold vacuum somewhere. Mine is attached to the throttle body and I capped off the fitting KB had on the adapter plate. If one of the barbs on the j-tube is open, that could be culprit to your recent idle issues. If you have hydroboost, you may not have a booster vacuum line.
As for moding the pcv system, I am thinking of doing something similar to what Cory is running as well.
Old Jun 2, 2008 | 09:48 PM
the 3rd barb has a threaded plug in it instead of a barb. I have the barb that belongs there. I think i'm gonna go put it in and hook the pass side vent to it. So with the catch can I'd have to run both lines to a T then into the catch can then out of the catch can into the J-tube right? does anyone make a catch can with 3 barbs? 2 in and 1 out
Old Jun 2, 2008 | 10:18 PM
andrew383's Avatar
traveling mod
http://s230.photobucket.com/albums/e...4081931-01.jpg
here's my catch can on the ss.i got one on the way for the truck pm me if anyone needs details on where i got it
lucas287
31
Jan 12, 2021 06:18 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
mhorn0817
Jul 8, 2017 01:54 AM
JordanH
Oct 3, 2015 03:59 PM
jroctpb
Aug 11, 2015 03:52 PM
