My LS1 fans, and my custom wiring harness
With the 2 relay harness, one fan comes on full speed with the PCM set point, the other comes on full speed with the A/C.
With the 3 relay (witch everyone seems to want) they both come on half speed with the PCM, if the temp is not met, and the A/C is on, one runs full speed, and with the temp met, and the A/C on, they both run full speed.
where does this or any other harness "tap" into the AC to know to turn on the fan when you have just started up a cold truck but want the air moving across the condensor that the AC actually cools off, I did this mod to my truck last summer and sweated myself silly every day for 5 min till the engine temp got up to the point where the computer turns the fan on and the ac actually starts to cool...???
Bueller?
Bueller?
Bueller?
Bueller?
I tap into the A/C wire that runs in the loom that goes behind teh red Batt box thats mounted by the alt.
I have the original prototype of his 3 relay setup on my truck, works great.
The wire for the a/c is the one that commands the a/c clutch to engage. I think it's the med. green one (get a multi-meter and test for yourself) in the harness pictured, just use a regular t-tap for the signal to the relay.
D1SCSS
Jan 25, 2016 10:14 PM
TimDave217
Aug 24, 2015 04:38 PM
