My Homemade Efans and Using pins 33 and 42
Old 08-20-2007, 08:26 AM
SS_bnoon_SS's Avatar
Originally Posted by BlackGMC
Here are my settings.
Damn, I wish HPT had all of those settings. My AC takes to long to get cold because the fans won't turn on soon enough when the engine is cool. Once the fans come on, it's very cold just like it should be.
Old 08-20-2007, 08:30 AM
Resident Retard
BlackGMC's Avatar
To be honest that was the deciding factor for me when I decided to buy Tuning software, cause everything else is pretty much the same...
Oh, last night drive I had the headlights, fogs, AC, radio, everything I could think of and the lights did not dim at all when the AC or fans cycled. And that is with the stock 105amp alternator...
Old 08-20-2007, 09:35 AM
11 Second Club
Phantom's Avatar
awesome job man
Old 08-20-2007, 09:44 AM
PT's Slowest Truck
budhayes3's Avatar
Excellent work, both in the fabrication and tuning...nice setup
Old 08-20-2007, 10:04 AM
03chevy5.3rcsb's Avatar
Very nice work, I know of a few guys that would be interested if you were to re-pop these. That is exactly what i was going to do, i just cant stomach the price of fal
Old 08-20-2007, 10:10 AM
Resident Retard
BlackGMC's Avatar
Actually I thought about it, but I don't think so, my metal brake and bead roller have a hard time working with 18 gauge sheetmetal (which is what I used) if I upgrade my metal brake I might consider doing it. If people were local I don't think I would mind....
Old 08-20-2007, 01:05 PM
Can you tell me what the stock on/off pressures are and the on/off speeds?
Old 08-20-2007, 02:06 PM
Mark Johnson's Avatar
Real sano lookin', even have room for a real sized air tube now to the intake........
Old 08-20-2007, 02:12 PM
Resident Retard
BlackGMC's Avatar
I can find out after work, I have a 05 and 06 stock tune at home I can pull the number out of. I think the numbers are pretty close except the #2 AC pressure I lowered that way the AC would be colder all the time.
Old 08-20-2007, 04:58 PM
Resident Retard
BlackGMC's Avatar
Here you go stock 05 efan settings. Remember these values are in PSI, not kPA.
The reason I changed the stock AC enable and disable was because the AC pressure usually sits 250-275, lowering the second fan value allows the fans to stay on full and provides the coldest AC when parked. That was after logging in 100* heat yesterday.
Quick Reply: My Homemade Efans and Using pins 33 and 42
