My harmonic balancer wobbles
Old Aug 23, 2008 | 01:06 PM
00ChevyScott's Avatar
Wearin' da big hat
Default My harmonic balancer wobbles
I can see a noticeable wobble in my harmonic balancer and its causing my A/C belt tensioner to move back and forth. Its been like this for about a month now ever since i did my cam swap. I think this could be because I tightened it down using a pry bar through it and a big TQ wrench to tighten it down. Is this going to mess anything serious up, or just cause me to go through belts/tensioners a little faster than normal?
Also, to fix this, do i need to buy a new bolt and redo the harmonic balancer?
Old Aug 23, 2008 | 03:22 PM
hirdlej's Avatar
You should not drive it with a wobble. That can't be good on the rotating assembly. Get a new balancer from a member and a new bolt. This time put it on with the impact gun at 200 ft lbs, that's all I did
Old Aug 23, 2008 | 05:44 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Well wobble may not be the word I'd use but mine moves around a bit and always has. My A/C belt tensioner (that little piece of crap) bounces up and down, always has.
Old Aug 23, 2008 | 10:46 PM
shakinlm7's Avatar
I replaced mine with an under drive pulley. PM me an offer if your interested.
Old Aug 23, 2008 | 11:11 PM
skeet's Avatar
yep i agree sounds like it got bent..
Old Aug 23, 2008 | 11:16 PM
Wearin' da big hat
Well I have to drive it, as it is my DD. It doesn't wobble too bad, and doesnt really look bent, but it does cause the A/C tensioner to move some. I'll try and take it easy on the truck and I'll go pick up a new bolt and see what kind of deal I can get on a harmonic balancer at work.
Old Aug 24, 2008 | 06:33 AM
Gordy M's Avatar
When you but the balancer back on there is a tool to us to get it on correctly and a torque procedure for the bolt. Do a search and do it correctly or you will have another failure. The bolts are a one time use and rather cheap, the torque sequence is something like torque to 37 ft lbs and then measure 240 degrees on balancer and torque to that point. It is several hundred pounds of torque and you need a way to hold the engine from turning. 3 ft pipe extension really helps.
Old Aug 24, 2008 | 08:07 AM
phasemaster1's Avatar
You mean old bolt 240ft lbs remove throw out, new bolt 37ft lbs and another 140 degrees.
Old Aug 24, 2008 | 08:09 AM
It dosent wobble to bad at idle maybe...but add a couple thousand rpm? I would change it.
Old Aug 24, 2008 | 10:52 AM
7845's Avatar
Banned
its a pulley not a balancer like old school motors. it will wobble alittle bit
and the crank bolt isnt really torqued using a torque wrench you need to do the Degree ordeal
