My 4.8 finally died :(
Old Sep 30, 2004 | 10:30 PM
Yellowsierra's Avatar
Default My 4.8 finally died :(
I have a problem with my 4.8 pushing oil out the vac. lines and out the oil dip stick. I was hoping that was just normal with a supercharger but it keep getting worse. It turned out having either broke rings or melted pistons because it has no compression in two of the cylindors. I was thinking about fixing it up with like a forged crank, rods, pistons ect. but the price was going to be really expensive. I thought about it and I think I'm just going to drop a 6.0 in its place. Guess what else decided to die on me yes my transmission.(4l60E)So I made some phone calls and found a 6.0 with 4l80E and they only have 6k miles on them. The price tag for the motor and trans is $3,500. Is that desent price for the two? So what do you think fix 4.8 or go with the 6.0?
Old Sep 30, 2004 | 10:39 PM
slowprocess's Avatar
Looks like a good price to me. Let's have a moment of silence for the old 4.8L.
Now, get to work with the swap!
Old Sep 30, 2004 | 10:48 PM
BlownChevy's Avatar
blownerator
25 Year Member
3500 is a great price for that combo! where was it?
Old Sep 30, 2004 | 10:49 PM
greentahoe's Avatar
Sounds like a great deal. Are you going to do the swap yourself or farm it out??
Old Sep 30, 2004 | 11:30 PM
derek_silvy's Avatar
Yeah, that is a good price it seems!
What is it exactly that you happened to the 4.8?
Old Oct 1, 2004 | 01:45 AM
Midnight's Avatar
Blowby most likely. Too much for that little 4.8.
I still like mine though Good luck with the swap and let us know how it goes.
Old Oct 1, 2004 | 02:11 AM
GoldenVelvet's Avatar
We all know that the 4.8 is just as good as a 6.0. Wait what am I thinking go with the 6.0
Old Oct 1, 2004 | 09:52 AM
ktmrider's Avatar
If the motor needs to come out then the 6.0 makes the most sense. Only price will be your determining factor.
BTW, the combo price you have is pretty good! Keep us up on the happs.
Old Oct 1, 2004 | 11:09 AM
The 4.8 was a great motor but I think the 6.0 will make up for it Thinks for the help and yes it was just to much blow by the rings or what ever happened but one way or another I'm going to tear into it to see what went wrong. Maybe to many rpms 6800 or to much boost 11psi or maybe to much timing I don't know but I will find out and will keep all of you updated. The crazy thing is I ran a 13.4 at 103 at the drag with it pushing oil into the motor. Thats pretty good when your running on only six good cylinders.
Old Oct 1, 2004 | 11:14 AM
What kind of supercharger were you using? And what other mods do you have. And finally were are you located?
In Springfield Il, there is a RCSB yellow 4.8 Procharged Sierra just wanted to know if it was you
