msd wires
are the msd or any other brand any better then stock wires? if i take my pacesetters off i will need new wires, luckly i had 7 extras , but i won't if i do it again
i run the taylor wires and there pretty good i guess. I went through 2 sets of bosch wires in 1 month and iv had the taylors for about 9 months with no problems. i think the factorys are fine but i had 60k miles on stock wires so i figured i should replace them. you will definately know if you get some cheap wires. for taylor wires and ngk plugs it was like $70 from summit.
Originally Posted by stone150
well when i installed them i destryed 4-5 factory wires and hhad to get beau to put them back on right
Originally Posted by jakebdb56
damn how'd you do that man? that's crazy. mine all came off pretty easy. I only had a problem with cylinder #2's wire getting really f'd up from the header clearance. I had an extra one layin around and just wrapped it with fiberglass wrap and stuck it back on. works good now.
Are you pulling the pacesetters off?
...i had to get plires to rip that little prong off of the plugs
i always use grease on everything. it can also protect the plugs sometimes from cracking. i used to have a problem with the damn plugs in the dune buggy cracking I guess from being exposed to the weather all the time. I grease em up reaaal good now and never have had a problem since. nothin a little lube can't fix
Originally Posted by FarmerBeau
Sometimes they are stuck on there from the factory. I use dielectric grease (can be bought at a local parts store in a little package for like a buck) and it pulls right off every time
