movin gas tank 4 exhuast
Old Dec 10, 2010 | 10:50 PM
04herod's Avatar
Default movin gas tank 4 exhuast
ok i am thinkin of moving my gas tank between the rear frame rails so i can run duals with out havin 2 y over 2 one side what do u guiys think. and i was also thinkin of runnin a tank out of a 98 2door tahoe and tryin 2 wire up the factory 98 pump and sendin unit. any of u guys every done this or herad of it beenin done with switchin 2 a fuel cell. thanks
Old Dec 10, 2010 | 10:52 PM
Atomic's Avatar
I have a gauge for that
What do you have now? Sounds like a terrible idea and a lot of work. Just cross over the axle then run a pipe over to that side in front of the spare.
Old Dec 10, 2010 | 10:56 PM
04herod's Avatar
i have a 2000 scsb 4x4 converted 2 awd
Old Dec 10, 2010 | 10:58 PM
Atomic's Avatar
Yea....new fuel lines, new evap lines, custom filler neck, custom mounting, no spare, and not sure if will hang down below the bumper or not but I bet it will....
Old Dec 10, 2010 | 11:20 PM
04herod's Avatar
ya but if i run a cell i got 2 do all that any ways rite? idk is y i am askin plus i dont want a tank n my bed
Old Dec 11, 2010 | 09:40 AM
mhotrodscooter's Avatar
I've thought about doing this too. Them tanks or deep, and will be hanging down below the bumper. But I think with a roll pan it would hide it, but I'm not sure. I got some pictures on here with some measurements. I was planning on putting the filler behind the brake light..
Old Dec 11, 2010 | 01:15 PM
TXsilverado's Avatar
i had true duals with the OEM gas tank in place. you dont have to Y over to the other side...
Old Dec 11, 2010 | 01:54 PM
ChevyTruck's Avatar
something else
I have true duals with the OEM gas tank in place also, all 3" pipping also I'm 4WD.
Old Dec 11, 2010 | 05:46 PM
04herod's Avatar
well were r u guys placin ur mufflers and duimpin the pipes if u still got the stock tanks
Old Dec 11, 2010 | 06:16 PM
ChevyTruck's Avatar
something else
Mine run down passenanger side and mufflers are under the bed mine come out on both sides of the bumper.
