Motor/tranny is in...... Problem...
Old Sep 5, 2005 | 12:39 PM
99Silver6.0's Avatar
Default Motor/tranny is in...... Problem...
Ok. I got it all in and now have a slight problem. When I reconnect my ground to the battery the god dam starter cranks?!?!? I hooked the harness back up the way it all came off. Anybody know what might have caused this?? Cause right now im lost.
Old Sep 5, 2005 | 12:57 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe the starter solenoid or starter relay is shorted? Might have gotten some coolant in the connections during the swap?
Old Sep 5, 2005 | 02:32 PM
I thought that myself and just got back from Oreilly having it tested. I thinkits fucked to the tune of $154.00!!!!!!!
Old Sep 5, 2005 | 03:12 PM
KLUG'S SS's Avatar
FormerVendor
Yeah I think it is outrageous what they charge for a starter, for about any vehicle. I just recently put a new starter on my exgirlfriend's Dodge Intrepid and she paid like $170-$180 for it.
Old Sep 5, 2005 | 03:18 PM
slammedS10's Avatar
sound to me like you dont have the wire on the right terminal of the starter, switch the connection and you should be set.
Old Sep 5, 2005 | 03:19 PM
budhayes3's Avatar
PT's Slowest Truck
Crap, that sucks. You must be dyin to get that sucker running
Old Sep 5, 2005 | 05:06 PM
Coban's Avatar
Damn, thats freaking expensive. The OBS truck starters were only like 30 after you brought back the core and thats with a lifetime warranty. I had no idea they were that expensive.
Old Sep 5, 2005 | 05:08 PM
Coban's Avatar
so was the solenoid stuck or what?
Old Sep 5, 2005 | 05:44 PM
5.3 racer's Avatar
make sure the soleniod hot wire isn't touching the hot wire to the starter.... they're fairly close and if not oriented right they'll touch causing continous cranking.
Old Sep 5, 2005 | 06:02 PM
It was the dam starter. It runs though!!
