more cam questions
Old Jun 7, 2005 | 09:51 PM
black4x4's Avatar
Default more cam questions
I'm about to install a 210/218 .551/.551 112lsa cam in my 5.3 and have a few questions one being are mainley push rods any good and wood a set of 7.4 ones work? next on the spark plugs will i need to change anything or not? and what is the best way to hold the motor still while loosening and tighting the crank bolt?
Old Jun 7, 2005 | 10:02 PM
yackowski's Avatar
I've never heard anything bad about manley push rods, and SDPC----> has a pretty good price on them. 7.4" are the ones as long as everything is stock. I wedged a prybar between the spokes of my crank pulley and had no issues.... would I recomend it... prolly not, and im sure someone else has a better idea on that one! Good luck on the install, its fun and really easy.
Old Jun 7, 2005 | 10:18 PM
black4x4's Avatar
what do you me by if everything is stock? cause i will have the crane dual springs tit. retianers hardend seats and then the vinci 062 cam
Old Jun 7, 2005 | 10:26 PM
yackowski's Avatar
Sorry, I meant like if you milled the heads and raised compression or something like that. With those mods you will be perfectly fine with the 7.4".
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
