more air for the Duramax
Old Feb 28, 2005 | 06:16 PM
Micheal Tomac's Avatar
Default more air for the Duramax
Here's a few pics of the ATS Aurora 5000 series turbo for the Duramax.
Old Feb 28, 2005 | 06:21 PM
XLR8NSS's Avatar
Adkoonerstrator
WOW, what are the specs on that sucker.
I take it that is only available for the LB7's?
Old Feb 28, 2005 | 09:02 PM
quicksilverado's Avatar
Thats a big a** turbo.
Old Feb 28, 2005 | 11:14 PM
Leroy_454's Avatar
Very nice tomac, I am assuming you are planning on using this turbo in the future?
Old Feb 28, 2005 | 11:37 PM
fullthrottledan's Avatar
damn thats a little bigger!!
Old Mar 3, 2005 | 12:44 AM
2.8" inducer
3" exducer
4" custom billet compressor wheel
60psi gauge recommended
This turbo was made to fit on the LLY Duramax but the PCM has to be dealt with to keep it happy without a turbo to control.
Old Mar 3, 2005 | 12:48 AM
yes, just need to install it.
Old Apr 2, 2005 | 12:58 PM
Installed the turbo, 4" downpipe, headstuds & 20% bigger injector nozzles last weekend. WOW the truck is scary fast in street trim at 7000#. The driveablilty is just short of amazing for such a large turbo. With the same programming as before plus 20% bigger injector nozzles I'm seeing 50psi of boost compared to 27 with the stock turbo and stock injectors. With more fuel from the 20% bigger injector my max EGT's are now are 1600 degrees compared to 1800 degrees with the stock turbo and injectors. Now the truck feels as fast if not faster than it was on nitrous.
Old Apr 2, 2005 | 01:57 PM
8ALTNG's Avatar
Damb. So how much tq do you think that thing is putting out now??? And seeing as how you are the inhouse diesel expert, what programmer do you recommed for a stock duramax??? I am going to do a cat back 4inch as well. Thanks
Old Apr 2, 2005 | 11:03 PM
speedy02's Avatar
That should help put you in the mid to lower 11's..
