modded tstat?
Old Apr 29, 2002 | 10:25 AM
Default modded tstat?
i've seen in several people's sigs they have modded tstats that are supposed to be the same as 160*. how is this done and does it really work?
Old Apr 29, 2002 | 10:52 AM
really slow truck's Avatar
Default Re: modded tstat?
modding the tstat is really easy and it works. I have it done on my truck.
to do it... just take off the thermostat, i think its only 2 10mm bolts (10mm??).
Next, push down on the thermostat untill the spring is down and you can twist it either way so that the thermostat will "pop off" the thermostat housing (there are springs on the inside.)
After this place a BB or something around that size in the little hole in the center of the inside of the thermostat housing which you will see once you remove the thermostat.
after this reassemble the thermostat and reinstall it on your truck and your finished.
do a search on the topic and see if you can find a picture from a while back that shows it a little more.
hope this helps <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
bryan
Old Apr 29, 2002 | 03:47 PM
YellowChevy4.8's Avatar
Would yall suggest doing that over spending 50 bux on a Hypertech 160* T-Stat?
Old Apr 29, 2002 | 04:28 PM
Brandon Boomhauer's Avatar
well seems to be a pretty cheap way to get a 160 stat compared to 50bucks for a hypertech......
Old Apr 29, 2002 | 04:48 PM
I can't tell any differance in performance since installation of 160* therm., exept that my trk. runs 180*. The install was easy,only problem was getting the hose off the old thermostat. The chevy techs say it is designed to run @ 210* but I'm use to seeing 180*, you know "old dog new trick". So far the best improvement I've achieved for the $$$ is the airraid filter settup. good hunting <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
Old Apr 29, 2002 | 07:04 PM
this really shouldnt be thought of as a performance mod per say. More of a safety mod that allows for other modification that DO infact increase performance. Cooler Engine = Less Detonation = Allow For More Timing = More Power <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . but yeah, if you just change the tstat your not going to feel any change in power. I did it so that i could run more timing on ls1 edit, which gave me a few more ponys <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Hypertech increases timing a little as well if you tell it you have a 160* tstat.
Bryan
<small>[ April 29, 2002, 07:06 PM: Message edited by: really slow truck ]</small>
Old Apr 29, 2002 | 09:46 PM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by really slow truck:
<strong>this really shouldnt be thought of as a performance mod per say. More of a safety mod that allows for other modification that DO infact increase performance. Cooler Engine = Less Detonation = Allow For More Timing = More Power <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . but yeah, if you just change the tstat your not going to feel any change in power. I did it so that i could run more timing on ls1 edit, which gave me a few more ponys <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Bryan</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good answer <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I unfortunatly did the Hypertech. Of corse I did it before this mod was getting around. Now I have two extra stock tstats.
Old Apr 29, 2002 | 10:39 PM
thank you! thank you! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
scary, a year ago i didnt know jack about performance. haha "wow! i can get 10hp from a tornado and a tb spacer!" but.. thankfully, nothing to do in collge + tech boards yeild lotsa good learning! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> heh
greg, u could always sell your hypertech on ebay, even if its only for like 25-30 bucks still better than not getting 25-30bucks for keeping the same thing. but then again, for 25-30 bucks, i would probably leave it on due to lazyness. haha
or... you could tweak those two to be 160* tstats, start making it sound REALLY hard to mod to them, and sell them both for 30bucks haha j/k
Old Apr 29, 2002 | 11:12 PM
BigTex's Avatar
Or - Sell the "mod your own thermostat" info sheet on ebay for $9.99. Take paypal, then just send the buyer a PDF of the mod. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 30, 2002 | 08:30 AM
GTO Forum Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TnTrk53:
<strong>The chevy techs say it is designed to run @ 210* but I'm use to seeing 180*, you know "old dog new trick". <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That Chevy Technician is correct. GM runs all their vehicles as close to 210 as possible for emissions purposes. A hotter engine burns off more hydrocarbons and other stuff.
