Misfire question
Old Dec 3, 2010 | 03:46 PM
lownslo's Avatar
Default Misfire question
I am helping a friend diagnose a misfire over the telephone on a 2000 model chevy truck.
Its giving a p0300b code and every revolution on 3&4 it misfires. Plugs were checked and changed and the coils and wires were moved and it didn't affect it. I suggested he check the ltft to see if it might be a clogged convertor, he checked and at idle it was 5.5 bank 1 and 7.2 bank 2. all the injectors are working correctly and he says the maf was showing frequency but couldn't tell me what exactly it was before i had to jump off the phone.
Next idea i had was a crank and cam relearn along with a flash of the pcm from the dealer???? What do you guys suggest?
Old Dec 3, 2010 | 03:56 PM
lownslo's Avatar
oh and you can rev the truck to 1500 rpm and it stops the misfire!
Old Dec 3, 2010 | 11:05 PM
incognitoZ71's Avatar
when you find out...LET ME KNOW!!!! its driving me iNsAnE on my 2000 silverado...i was told i should check the O2's but mine are doing the same thing your friends are, working fine that is.
Old Dec 3, 2010 | 11:58 PM
budhayes3's Avatar
PT's Slowest Truck
Is the truck in question stock or modded? Cam?...tuning for cam? How does he know that the injectors are working as they should? Just because their being commanded doesn't mean that their doing their job (not saying that an injector is the problem, especially since the misfire only seems to be at idle, just curious how they checked the injectors).
Vacuum leak? Tell him to try spraying some carb or intake cleaner around the intake ports and whatnot and see if the idle and AF readings change when doing so...
Old Dec 4, 2010 | 12:52 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
i had a 2000 that would miss bad on 3 and 4 at idle... BAD i thought it was low compression.. but it ended up being the fuel pressure regulator was shot
Old Dec 4, 2010 | 10:45 AM
budhayes3's Avatar
PT's Slowest Truck
Hmm, that's cool, and an easy fix...pull the hose and see if fuel comes out...
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
andrewlong
Sep 8, 2015 10:25 PM
