Mild Setup - Opinions
Nelson?
Yes, Allen tuned my truck. My other few mods are LS1 fans, FIPK, TransGo/billets, and a Flowmaster
lolIt runs way better than it did stock for sure. But economy also comes from how you drive...my truck doesn't see much past 50% throttle often much less WOT. It doesn't run much faster that way anyway.
What kind of numbers do you think I'll see with this setup and a mild tune from Allen? Mpg and 1/4 mile? Think that cam will help the low end torque a bit?
I think with a tune and cam .5-.7 is realistic. The LS1/6.0 cam is going to make power or at least remain flat to 6000rpm whereas the stock truck cam in the 5.3 falls out that high.
You may not gain any low end or lose any, the cam has just a few more degrees of duration and a wider LSA making that responsible for its pull to a higher RPM.
Ha ha ha ha! Awesome! Thanks alot...I especially like the part when the guy in the Mustang says "If you post this on your board or whatever, You're a** is in deep sh*t"....didn't have my bottle on...ha ha ha!
I've seen that before Mustang: If you post this on your board or whatever, You're a** is in deep sh*t
Truck: Why's that?
Mustang: because......................
HAHAHA
Yeah, a tune would be good I've heard Nelson and Edit are good although Edit is a do it yourself tune. Sombody post Edit's website
.i hear hp tuners is alot better though : www.hptuners.com
Originally Posted by SportSide 5.3
otherwise they are exactly the same, except for the software bit.
but what ever you can do with edt, you can also do with HP.
heres what alot of the f-bod guys said about it. pretty much what you said thunder.
https://ls1tech.com/forums/showthrea...edit+hp+tuners
PT's Slowest Truck
Originally Posted by BADMOFO
I think that cam you picked is too small. I'd go with at least a 212/218 if your going to go thru the trouble of putting a cam in.
mitchellmade
Sep 27, 2015 08:25 PM
echoman
Aug 22, 2015 01:53 PM
