Mild 6.0?
Old Jul 22, 2004 | 08:06 PM
SBChevrolet's Avatar
Question Mild 6.0?
I am looking for the truck now Im looking for a RCSB 2WD 1500 auto
I though about a LS1 swap and then about Radix, but I dont see 6grand in my budget when im still going to be paying for the truck (and im 18) I would like to have around 380RWHP and a little better then that in TQ I was just wonding if this would be possible with the mod I was thinking about doing along with a 6.0 swap
6.0 LQ4
Hamm Headers
True Dual Exhaust(with H-Pipe)
Volant Cold Air Intake
Nelson Tune
Cam(unsure of which one yet it has to be streetable but still have a little lope and plenty of TQ)
Electric Fans
I would also probably do like 2600RPM Stall Converter
Im needing to keep this truck very streetable and pretty conserative on gas because once I get this truck set up pretty Nice I have another project I really wanna get to
Old Jul 22, 2004 | 08:18 PM
gcooper's Avatar
One poor newbs advice to another. First thing i would use an x-pipe they are supposed to flow better. if you are tight on money you can make your own intake. A lot of people on this forum like the 212/218 comp cam. I think for the 6 liter the high lift version would be better. Also you can probably use LS1 fans instead of shellin out the 400 for flex-a-lites.
Old Jul 22, 2004 | 08:27 PM
opps thats a type o I deffently ment to say X pipe...
Old Jul 22, 2004 | 08:38 PM
parish8's Avatar
single digit dreamer
sounds like a great plan to me, i dont think you will see 380rwhp but it will run prety hard.
6.0's do like to eat fuel though. i wouldn't expect over 14mpg with it.
Old Jul 22, 2004 | 08:56 PM
What kind of numbers should I expect then? Dident your 6.0 put down somthing like 314 RWHP stock?
Old Jul 22, 2004 | 10:35 PM
parish8's Avatar
285rwhp with CAI, tstat, electric fans and cat back pulled, 322rwhp adding a cam
those numbers are thru a tcase and 4l80e so they would be a little higher in a 2wd and then add the headers and you will probably be close to your 380rwhp.
i would go a little steeper on the stall, a 3000 is still prety mild. i could see 13's with what you have planed and some traction.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
