Might be a stupid question but...
Old Jul 5, 2011 | 01:29 PM
stranger ranger's Avatar
Default Might be a stupid question but...
I've always known a clogged cat on late model vehicles to throw a code, however is this always the case? Will it always trip a code if something is wrong with them? I have a friend here at work today asking me and I didn't want to give an answer not knowing fully.
04 silverado with the 5.3.
Thanks Gentlemen.
Old Jul 5, 2011 | 05:34 PM
budhayes3's Avatar
PT's Slowest Truck
It *should*, but sometimes strange things happen. I've seen cats clog, and cause misfires and no power above 4k, and the only codes that were thrown were multiple misfire codes...
Old Jul 5, 2011 | 08:14 PM
LsF-150's Avatar
Been working on cars for 20 yrs and hav'nt seen an ses light help diagnose a clogged cat...whats the truck doing? easiest way to diagnose a clogged cat is drop the y-pipe and drive it...i assume its down on power, check codes, fuel pressure and volume, drop the y-pipe, un-plug the maf...that should get you started.
Old Jul 5, 2011 | 08:47 PM
budhayes3's Avatar
PT's Slowest Truck
...or you can hook up a vacuum gauge and see how it reacts. If you rev the engine up above 2500 and snap the throttle shut, the vacuum gauge should quickly jump up, usually over 20 mm/hg. If it slowly creeps, there is a restriction in the exhaust. A backpressure tester in the suspected bank's front O2 sensor bung will also tell you if the exhaust is restricted.
Old Jul 5, 2011 | 08:48 PM
terravast4's Avatar
I had p0300 multiple misfires and shitty power up top.......
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
