Mid to High RPM Cam for a 5.3
Old Sep 22, 2008 | 03:18 AM
j200pruf's Avatar
Default Mid to High RPM Cam for a 5.3
That will still pass emissions
This is gonna go in a fairly light car with headers and a stock intake manifold(LS1). Power isn't a huge goal for me I would be very happy with 300rwhp but oh well if I don't get it. I have found that I am looking for about -3 to -6 degrees of over lap to have a chance at getting through emissions.
What is everyones thoughts on a 227/224 on a 115 LSA? The higher lsa gets the overlap about where I want it and the valve events don't look like they are that far off of a 224/224 on a 114 (I can post the numbers up tomorrow).
What is every ones thoughts, reverse split bad? Any ideas for me post up
Old Sep 22, 2008 | 04:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
That sounds like a nice cam grind actually , I'd just run one and go for it... Whats it going in just to be nosey lol...
Old Sep 22, 2008 | 01:06 PM
j200pruf's Avatar
1987 Rx7, the car is really stripped out and doesn't weigh much. Still not sure on what to run for an exhaust yet.
Old Sep 22, 2008 | 03:06 PM
Turbo_Z's Avatar
I put a 5.3/4l60e in my 87 rx7 and I used comp cams 265xe cam. I also have long tubes, ls1 intake/injectors. This will be my daily driver and I figure that cam is good to 6000rpm on a 5.7 so it should be good to about 6300 on my 5.3. Lots of people want to throw in big cams to get the hp but I just want a great daily driver. I got it fired up but still have to remove the vats and tune it. Ill post back to see if I should have gone bigger when I make some more progress.
Old Sep 22, 2008 | 04:37 PM
zippy's Avatar
That is not going to be very emissions friendly...
Old Sep 22, 2008 | 05:49 PM
j200pruf's Avatar
I thought it would have a decent chance, a 224/224 on a 114 LSA has -4 degrees and a 227/224 on a 115 LSA would have -4.5 degrees of over lap. And quite a few people in CA have got similar 224 cams to pass, and my emissions are not as strict as CA, I only have to pass at idle or 2500RPM, no dyno. Do the 5.3s need a bit more - overlap to pass emission do to the smaller displacement than a lager ls1 would need?
Even a 222/224 on a 112 LSA has even less negative overlap than the other 2 cams I have listed. Zippy do you have to test your truck zippy or do they just do OBDII plug in test?
Old Sep 22, 2008 | 05:53 PM
InchUp's Avatar
If it's really light weight then cam size can surely be upped, but I'm not sure a 224 cam that aggressive is necessary to make the power you're after nor will it be easy to pass emissions. Have you looked into the CompCams 212/218 high lift? I think that's what Turbo_Z is talking about, it's definitely a good cam for the 5.3L with an operating range of 1600-6500+ easy if you have the head work to support flow up there.
http://store.summitracing.com/partde...1&autoview=sku
Old Sep 22, 2008 | 06:00 PM
bluecajun5.3's Avatar
11 Second Truck Club
i would opt for the tr224/114
it's a great all around cam and many people have no problems passing emmisions with it.
Old Sep 22, 2008 | 06:19 PM
zippy's Avatar
I live in Michigan, land of no testing. We have the same emissions laws as almost everyone else, just no testing to prove you meet them.
LCHEE
Oct 24, 2020 04:10 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
