Max boost with Whipple???
I'm currently running 8psi and want more. What's the max? I heard 12 was about the limit before the belt starts slipping. Should/could I go from 8 right to 12? I am running a SMC alcohol injection kit so I think I should be able to prevent most KR.
So you got the KR issues worked out?? What settings are you running on the controller, i.e. pump speed and turn on point??
I have heard of people seeing 12.4psi with no slip.
I have also heard you can reclock the tensioner to get A TON of tension on the belt. That thing wouldn't slip with a roller skate wheel on!
--so I've heard
--so I've heard
Ditto on the tensioner...I'm all about Reclocking School...
I'm running 11 PSI on my 5.3 right now. 358 RWHP / 472 RWTQ No belt slippage, although the tensioner sure likes to move around alot on quick deceleration!
holy old topic, but, i started it so i don't care. lol
I think i know what is meant by reclocking the tensioner. i'm gonna do it soon. on mine, the tensioner is held on by a bolt right thru the middle of it, and there is a tab that comes out the back of it into a hole in the mounting plate. if i were to just drill a new hole in the mounting plate a litte further to the left, that would put more tension on the belt. I'll take pics if/when i do it.
