Mass Air?
Old Feb 17, 2008 | 04:26 PM
WFOsierra's Avatar
Default Mass Air?
The honeycomb in the mass air, Should it stay or should it go?. Is it gonna help more then it will hurt in the long run after the MAF sensor gets dirty?...A friend of mine has had his out for a while and he said he sparays a lil MAF cleaner ever once in a while and has had no trouble....
Old Feb 17, 2008 | 04:37 PM
xlcooplx's Avatar
leave it in.
Old Feb 17, 2008 | 05:16 PM
andrew383's Avatar
traveling mod
use the search up top........
Old Feb 17, 2008 | 06:13 PM
Z71man's Avatar
Arrow
i took mine out and i havn't had any problems out of it. i actually could tell a small diff. the newer trucks don't even come with that anymore. i clean mine everytime i change my oil and thats bout it. i found out about in a haynes book while bein bored at work. lol autozone.....
Old Feb 17, 2008 | 09:16 PM
DrX's Avatar
DrX
The screen smooths out the flow for accurate air mass determination.
Best case scenario you gain 2-3 hp. Worst case, you run lean. The screened end of the tube is wider to compensate for the screen resistance.
Old Feb 17, 2008 | 09:28 PM
LMSeven's Avatar
https://www.performancetrucks.net/fo...d.php?t=395748
You'll want to scroll down to the "parts that don't work" section.
Old Feb 17, 2008 | 10:53 PM
truckmann's Avatar
I say leave it in.
Old Feb 17, 2008 | 11:06 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
+1 leave it
Old Feb 18, 2008 | 12:11 AM
Onetogofast's Avatar
If you pull it out, I would retune for speed density.....not mass air
Old Feb 18, 2008 | 08:23 PM
054.8 silverado's Avatar
The new trucks do come with 'em and its on there for a reason....
