mandrel bent exhaust
Old Jan 10, 2011 | 08:52 PM
matt29201's Avatar
Default mandrel bent exhaust
has anyone here built a dual exhaust system using mandrel bends? if so could you post up any pics to show how you ran it. i have been trying to decide what i need to order as far as the bends and tubing goes i have pacesetter lts and plan on running a x pipe into either bullets or moroso spiral flow mufflers. any information or pics would be greatly appreciated.
Old Jan 10, 2011 | 09:23 PM
YenkoST's Avatar
Yep...sure have....ran over the crossmember, under the trans tailshaft, then down the passenger side with an X pipe, mufflers, and then dumped at the bumper corners on each side. I ran Aerochambers mufflers.
I believe i bought the starter kit from a non sponsor I want to say that was T409 stainless and welded it up myself.
Old Jan 10, 2011 | 09:39 PM
matt29201's Avatar
thats the information im lookin for. i was thinkin of running it under the transmission pan in front of the crossmember then over the passenger side of the transmission crossmember into a narrow x pipe and into the mufflers and dump it in front of the rear axle. just wasnt sure if i had enough room over the driver side of the crossmember to run it that way.
Old Jan 10, 2011 | 10:44 PM
CashDudeHomie's Avatar
Mine is over the driver's side too. Just zip tie the shift cable out of the way.
Old Jan 10, 2011 | 10:59 PM
zachm89's Avatar
I built my cat back out of single 3.5" mandrel bends...you could easily do 2.5" duals in the space that this 3.5" is in. My truck is awd though so I used the y pipe supplied with the headers for the crossover to the passenger side that is run infront of the transmission cross member then down the pass side of the truck. I would think dual 2.5" would be plenty for your setup or single 3.5" like mine I love it!
Old Jan 11, 2011 | 05:51 AM
Gadgetized's Avatar
I made mine out of dual 3" T409 stainless mandrel bends. I used 7 total (I think I even have one kicking around, so maybe 6). I used 6 V-band clamps. I decided to do mine when I did the 4l80e swap. I have lt headers to high flow cats, X crossover behind the tailshaft, running next to the pass side of the driveshaft, dual in/ dual out magnaflow, tailpipes run up and over the axle, and out the back of the roll pan. I will try to put up pics, but it is sort of hard as I am on my phone. I am very happy with my exhaust.
Old Jan 11, 2011 | 06:03 AM
Gadgetized's Avatar
The roll pan isn't painted, but you can see how it exits. I also used a 10' length of stainless 3" tubing.
Old Jan 11, 2011 | 01:16 PM
slowec's Avatar
Hey Matt, note them V-band clamps. Nice job Gadgetized, what welder was used ? Give us some specs on that if you would.
Old Jan 11, 2011 | 04:08 PM
matt29201's Avatar
i see em. you think i need em at the collector and the muffler?
by the way thanks Gadgetized for the quick response on the pictures i got alot of new ideas running through my head now.
Old Jan 11, 2011 | 04:17 PM
Gadgetized's Avatar
I used a Hobart 140 with stainless wire and gas. I just bought the welder before I started the tranny and it was perfect for the job. I am one of those guys that can never make my mind up, and end up changing things. I have to say I would not change anything about the exhaust system.
