Making the L31 all that it could've been...
Old 06-19-2018, 12:31 PM
sharpe.trey's Avatar
Default Making the L31 all that it could've been...
Looking to fully utilize the L31's performance that GM could have possibly done via OEM. It's just a street truck no need for max performance but would like to get all that i can out of the L31 intake without the marine manifold. Not saying I wont eventually go to the marine manifold later, just trying to utilize the stock engine max potential.
ZZ4?
GM845?
GM395(ramjet)
GM846?
Hot cam?
Thank all that take a look and give me serious feed back, I have other project for the LS swaps, so just give me what ya can on this.
Old 06-24-2018, 10:27 AM
dab2pds's Avatar
updated mine with a 411 swap using the stock harness. Ran the stock injection with a comp cams 220 truck cam and the stock fuel injection was barely enough for that. there are several manifolds besides the marine available. holley 9901-107 and edelbrock 29135, both of which will require regular injectors and fuel rail. Went to the holley intake and 388 cubic inches and a 236/242 cam now in a 2 door 4WD Tahoe. Going to step up to the super victor now and see how that does. Obviously you would need a converter if you went that route, I am running an FTI triple disc lockup that stalls 4200ish behind my motor with 4.56 gears and 33 inch TKOs. Gets about 12 mpg on the highway running 80+ with this setup, and 8-9 mpg around town and rides like a Cadillac lol.
Dave
Old 06-24-2018, 09:20 PM
dsmmace's Avatar
I would build a 383 personally. Blueprint Engines are pretty decent daily driver motor options as well. Max effort L31, you can do much better with a LS Swap in my opinion.
Old 06-28-2018, 03:40 PM
dab2pds What cam would that be the closest to from the options I put up?
Old 06-29-2018, 06:24 AM
9 Second Truck Club
stock48's Avatar
A 383 would definitely be best if you can get fuel to it. There used to be a place that upgraded the spider assembly and regulator. Years ago I had a 97 L31 truck and did flat top pistons, little head work and my 217/225 .485/.505, 112 lsa camshaft. Made a HUGE difference but I had trouble getting enough fuel to it at wot. Cruise mpg did not seem to change much.
Old 06-29-2018, 10:08 AM
sounds like it was a nice ride minus it running a little lean possibly, I'm not expecting to break any speed records but would like to play with other trucks on the streets while having practical usage of a truck for a truck.
For the basic build it's really just a zz4 cam, s10 stall, gm's injector upgrade, vmaxx manifold spacer, full exhaust and tune. simple but should be a pretty nice combo.
idk If it'd would have any chance in a street race against newer vehicle but it would definitely be a fun useful daily driving truck.
Imagining that'd maybe put me close to 300whp
For what it's worth I've also thought about Lloyd Elliot cams off of his page.
Old 06-30-2018, 09:19 AM
dab2pds's Avatar
What year is the operating system for the truck? 98 and 99 black box computers can be tuned using hptuners. The other years limit your tuning options with a cam. They can all be repinned to a 411 computer using the stock harness, takes les than 2 hours and gives you much more tuning ability. The Comp cams extreme 4x4 line is good to go with a change to ls6 springs. The cam that I used with stock cubic inches and intake manifold was the 8-408 Comp cam
Old 06-30-2018, 11:24 PM
it's a 98, thought about the 0411 but was willing to see what I could get out of the black box first
abailey55 (02-01-2023)
Old 07-03-2018, 11:00 PM
between the ramjet cam, sp350 and the zz4 cam does anybody wanna talk about the differences between the 3 besides what the numbers on the paper are?
Thanks
Old 07-09-2018, 12:29 PM
Skip Fix's Avatar
Jet/Tuner Cat has a program that can tune the black box-as well as LS versions.
Quick Reply: Making the L31 all that it could've been...
