Magnaflow Spun Cat
Old May 8, 2009 | 08:14 PM
BigMikeGXP's Avatar
Default Magnaflow Spun Cat
Just installed Pacesetter LTs, 2.5 inch dual exhaust, x pipe, and spintech sportsman street mufflers. Now its way too loud, resonates like an airplane, and rasps 1500 to 2500 rpm. So im thinking about putting some aftermarket cats back on it. Had a spintech with the stock cats/manifolds and it sounded good.
Anyways was looking at the magnaflow "spun-cat". They are small enough to fit. But I can't find anywhere that says whether they are stainless or aluminized steel. I was hoping to just cut out some pipe and weld them in place, but im thinking that won't work if they are stainless.
Anyone have any experience with them?
Old May 8, 2009 | 08:17 PM
MASS seller approved
They are stainless. We used to use them all the time, they will weld to the aluminized exhaust with no problems.
Old May 8, 2009 | 08:21 PM
BigMikeGXP's Avatar
Ok, thanks. Ive mig welded stainless and steel, but never together. Ill have to give that a try.
You say "used" to use them... any problems?
Old May 8, 2009 | 09:15 PM
No problems, they just didn't make much of a difference. I would only use them again if I ever had a car that needed to pass a visual inspection, but we don't have inspections here in Michigan.
If I were to run cats again, they would be my choice of cats.
Old May 9, 2009 | 01:46 PM
S/C Z71's Avatar
Banned
Haha. Should have kept the cats. So many people make this mistake. Don't feel too bad.
Old May 9, 2009 | 02:41 PM
Whippled 496's Avatar
I used them on my setup and have no issues. I used the 3.5" in/out CAT so a reducer had to be welded in.
Old May 9, 2009 | 03:52 PM
zeake's Avatar
I think I still have a set of these cats used if you are interested. I think they have less than 10k miles on them. I will have to check at work monday. $110.00 shipped. I will get pics for you if I still have them and you want them. Email zeake13@yahoo.com
here is a pic of one of them.
Old May 9, 2009 | 03:59 PM
BigMikeGXP's Avatar
ok thanks yall. Im probably just going to buy some new ones. thanks for the offer though.
Old May 10, 2009 | 09:30 AM
zeake's Avatar
No problem. you will like the sound.
03sierraslt
14
Oct 9, 2015 05:53 AM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
