magnacharger.......
Old Oct 10, 2003 | 08:29 PM
ta12sec's Avatar
Default magnacharger.......
Would anyone with a magnacharger system like to take some measurements for me please? I am looking for the bottom of lower intake to top of lower intake, and the bottom of blower to top. along with the measurement from front of intake to rear most part of blower. lastly the measurment from the manifold to top of blower in rear. Thank you very much in advance.
Old Oct 10, 2003 | 08:52 PM
Default Re: magnacharger.......
I'll measure mine tomorrow,go to the hybrid and conversion forum,click on the Speartech link at the top,I think you can find a picture of a truck accessary drive there.
Old Oct 10, 2003 | 09:21 PM
ta12sec's Avatar
Thank you and tia for the measurements
whitt1
Old Oct 10, 2003 | 11:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
There two different systems available,one is for the trucks and one is for the vette. what are you trying to fit it on?
Old Oct 11, 2003 | 01:33 AM
ta12sec's Avatar
I have the vette mesurements I just was curious what the trucks were. I will find some way to have a roots blow ls1 f body.
Old Oct 11, 2003 | 12:02 PM
Ok as best I can tell with a measuring tape the bottom of lower intake to the bottom of the blower is 3.25",the blower height is 5" and the measurement from the back of the supercharger intake tube[trucks have a rear facing blower inlet and long intake tube to a foward facing throttlebody]to the front of the lower intake manifold is 21",this measurement could be reduced by about 1.5" by pluging and relocating the rear vacuum port.The hose connections for the heat exchanger are under the intake tube to the rear of the blower and should'nt be a clearance problem.I think the system would intrude far enough into the cowling that you might have to redisign the wiper mechanisim.But I also think the direct drive pulley at the front will offer a real advantage,when you go to a smaller pulley to increase boost.
Old Oct 12, 2003 | 02:02 AM
ta12sec's Avatar
Thank you very much for taking the time to do that for me.
Old Oct 13, 2003 | 04:54 AM
Flyer's Avatar
They should all be the same except for the height. The truck Radix blower has the intercooler which would add an inch or so (just guessing) to the overall hieght.
